Old 03-23-2023, 11:30 AM
Tom Vaught's Avatar
Boost Engineer
My conclusion was that there is more science and calculation required to optimize an intake manifold than just changing flanges. FWIW.
Have to agree with that statement.
The Mickey Thompson Crossram for the early engines, (even with the balance tube added), looked cool but did not perform anywhere close to the later 4BBL intakes from Edelbrock and other sources. Skip Fix has posted about this too.
Tom V.
Old 03-23-2023, 04:26 PM
RBAILEY RBAILEY is offline
What I did with the stuff blocks was:
1) Measure the port opening of the heads you want to use.
2) Measure the Gutsram and the ports at the entrance to the plenum.
3) Subtract the Head Runner dimension from the "Plenum" dimension".
divide that dimension by 2.
4) Make your stuffer blocks so that the bottom of the stuffer blocks blend with the Head Port Opening.
5) Make the top of the stuffer blocks so that the runners have the same dimension for the runner (Left to right) at the top is the same as the bottom of the intake runner.
Drill holes so that you can tap and screw retention bolts thru the outside of the runners into the stuffer blocks. That keeps the screws away for your engine parts.
Not a thing wrong with Larry's Gutsram. Just needs to be "Runner VOLUME Tuned" for the application.
Tom V.
Thank you Tom.
Old 03-23-2023, 09:12 PM
Tom Vaught's Avatar
Boost Engineer
You are welcome Mr Bailey.
Tom V.
