need to know where to install holes for a spoiler
does anyone have specs on where to drill the holes to add a spoiler onto a 71 lemans?
come on someone has to have the specs
If you have an original Judge style spoiler the front edge of the pedestal (not the stud!) is 16" from the front edge of the decklid, center it from side to side. Lay some 2" wide masking tape roughly where the bolts will go & hold the spoiler in place to mark around the studs on the tape.
I don't have the exact dimensions for the holes but this should get you close. |
Here is a link to the instructions found on ames website.
http://www.amesperf.com/assets/images/70spoiler.pdf
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
thank you, you guys are awsome!!!!
