Old 08-09-2003, 09:28 AM
64speed's Avatar
64speed 64speed is offline
I am going to take out my points type distributor here this week and put in and HEI. what wire to the coil is used to power the tach and do I just plug it into the tach feed on the HEI?
64speed's Avatar
Old 08-09-2003, 01:41 PM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
theres a place to plug the tach into right next to the power feed. its marked tach
http://gto.1colony.com/
Old 08-09-2003, 03:20 PM
64speed's Avatar
Yeah Iknow that I am very very familiar with the GM HEI...I just dont know which wire on the factory coil that powers the tach now. Which wire do I plug into the HEI?
Old 08-09-2003, 04:22 PM
sandmanjoe's Avatar
it should be a solid black wire thats the power wire,+side of the coil. at least thats whats on my 65gto
and i believe that the tach wire would be hooked to the neg side of the coil.
Old 08-13-2003, 07:42 AM
HenryGriffith's Avatar
HenryGriffith HenryGriffith is offline
Another interesting detail on the '65 factory tach wiring. It connects to the negative post on the coil. You can't miss it. It has a cheap looking in-line plastic fuse holder (like what comes with car stereo installation kits). I thought the in-line fuse was some tacky addition for something, until I found out it was Factory Installed for the tach!
Old 08-13-2003, 09:44 AM
sandmanjoe's Avatar
what size is the fuse?
Old 08-21-2003, 12:12 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
3 amp, a very short glass fuse. The old style fuse.
Peter Serio
Owner, Precision Pontiac
Peter Serio
