Old 01-04-2018, 10:42 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Rack an pinion
Has anyone found a kit or made an adapter to fit a 61-63 Tempest- LeMans?
Old 01-04-2018, 11:42 PM
blueghoast's Avatar
Ask R70 Judge He did a rack + pinion on his 63-LeMans.
He can lead you in the wright direction.
GT.
Old 01-05-2018, 10:29 AM
Radman's Avatar
Radman Radman is offline
I used a universal rack from Flaming River on my 62. It is a mustang II style rack. One note, get the Ford power steering pump in the GM body from them also. If you go with a normal GM pump which has a much higher pressure and flow rate, you will end up with a hyper sensitive steering system. We cut the bow shape off of the front of the cross member, split a drive shaft and welded it into the cross member, then mounted the rack.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
