Yes, if not it drives the pointer to an attitude which the gauge would never see during normal operation. By electricity power turned into magnetism the gauges can move their pointer further that your "view window" however that is undesirable especially when working on something 50 years old or older and is in failure mode anyway. There is a normal "sweep" to each gauge, and that includes what is indicated by those thin white lines. Anything beyond that is bad, with one exception.
And that would be for the temperature gauge; the topmost line which just says "C" everybody knows that stands for cold. Your normal start position is that line but I have seen many temp gauges (68 & '69-70) where the start position (cold engine) is slightly above that line which, in my opinion is totally normal. The top line or just above that line. Once set into motion by rising coolant temperature; that is where the other lines need to be right on the money!
Hi Peter
You have been recommended by OG68 and will send you my gauges next year. I have a 69 GTO and there is a 140 mph speedo Rally Gauge cluster in it which narrows my cluster down to a 69-71 Grand Prix or 70-71 GTO. I also have a 68 Rally Gauge cluster, temp indication no 100-250 just graduated. Will the 68 cluster work in my 69 GTO once I get it refurbished. Both clusters temp. indications are faulty (not showing needle not there.). Also I am looking at finding a 69 GTO in dash tach (currently clock in it and not working) and I have a Summit HEI ignition in the car and the conversion kits Ames offers do not offer one for a 69 and same for their reproductions. Also when my cluster is lit the faceplate has a slight greenish tinge to it. Any information you could provide me would be appreciated. Please leave my your website address for future reference. Thank You Carousel72TRed |
That said I have not spoken with Peter but if you would like to correspond with him you can 'Private Message' him. To do that, click on Peter's name, a drop down box will appear, select Send a private message to Peter Serio. To look at private messages or access other functions scroll to the top of the page and click "User CP". I'm not sure how often Peter logs in to the forum but he will most likely respond to a private message. Hope this helps, Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
http://precisionpontiac.net/ He restored my rally gauges and converted my tach to run on an HEI.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
Thread Tools | |
Display Modes | |
