Old 10-24-2019, 11:23 PM
allenga allenga is offline
Default 77 TA- Mild Refresh
My original car is getting a once over. New paint, rubber, glass, decals.
ID:	522880   Click image for larger version
ID:	522882   Click image for larger version
Old 10-24-2019, 11:32 PM
Attachment 522885More
Old 10-25-2019, 08:12 AM
68tpls400 68tpls400 is offline
Going to be stunning!
Old 10-25-2019, 08:20 AM
TAKerry TAKerry is offline
Looks nice and solid. Not many original fenders around with no rust.
Old 10-25-2019, 08:38 AM
77 Canamman's Avatar
Looked great before. I'm sure it will be outstanding after.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 10-25-2019, 09:50 AM
Bentwheelbob's Avatar
Originally Posted by allenga View Post
My used to be original car is getting a once over. New paint, rubber, glass, decals.
Fixed that for you....
I'm sure the car will look great. Good luck.
Old 10-25-2019, 10:18 AM
I don't feel any loss for my original paint. It was all checked.
Old 10-25-2019, 08:32 PM
77 TRASHCAN's Avatar
Good time to work on the engine!
The factory paint on my car was very poor. Did look god at 20 feet, most importantly....
Shut it off
Shut it off
Old 10-26-2019, 06:28 AM
In response to your TAC post, you won't find red seatbelts sleeves. Even the ones you have pics of are both reproductions and both painted. They are poor quality and more suited to 74-76 depending on belt type, which was also not advertised by the seller. I have a set, not cheap to import, can't give them away here. But regardless, you'll have to dye a new or used set, problem is if it matches you red interior for level of existing fade.
Old 10-26-2019, 02:25 PM
I wish I could. Not in the budget. I will do some quick upgrades, headers, DUI distributor and carb rebuild.
Old 10-26-2019, 09:10 PM
In response to your TAC post again, the sleeves are no longer available. They were through F-Body Store and closer to $110/pr when I got a set years ago, F-Body Warehouse were one supplier who also recoloured them. You may want to contact Pete and check. They were poor quality, and the recoloured versions were not even cleaned up prior to paint. They were for the large chunky plastic block style receivers. If you have the chrome deluxe buckles, keep looking.
There's a pic of the red belt style in my ebay ad, check it.
http://fbodystore.com/1973-1981-tran...ver-set-front/
https://www.ebay.com.au/itm/16391228...84.m1555.l2649
Old 10-30-2019, 10:40 AM
ok never mind
Old 11-10-2019, 09:57 PM
Gen2guy's Avatar
Gen2guy Gen2guy is offline
Keep the pics coming she's gonna look great when you finish. I looked for a black TA for a good while just wasn't out there in the condition I wanted to start a restoration in.
The Following User Says Thank You to Gen2guy For This Useful Post:
Old 12-17-2019, 09:03 PM
Default Progress
Fenders, hood, trunk lid in same state. Danko spoilers and chin get the treatment next..
Old 12-18-2019, 09:07 PM
Gen2guy's Avatar
You're moving at pretty good clip looking good keep up the good work
Old 12-18-2019, 09:19 PM
Clean up behind the rear bumper brackets, usually trapped moisture and rust.
Old 12-18-2019, 09:48 PM
Old 12-18-2019, 09:49 PM
schweet
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 12-22-2019, 10:38 PM
Exciting..
Old 12-23-2019, 08:50 AM
Thumbs up
Black is beautiful..
The Following User Says Thank You to 77 Canamman For This Useful Post:
