My car is a 1964 lemans it never came with a 4 cyl as far as i know, so it wouldnt have that resistor. But maybe i can get one of those babys to fix my problem?
My Half AN Injun..... |
I have to say though Tom, you are right on the money with what you discribed on my engine.. Thanks...
No problem.
Thank you..
Thank you for the link..
I've never had occasion to use one, so I have no actual knowledge. I just did a search to see if there was such a device, and came up with that. The seller says he will E mail you help if you have any problems during install. That's abut all I can offer.
I would try that and direct to coil
Carburetor building & modification services Servicing the Pontiac community over 20 years |
Ok thanks
Do you know where to get one of these resisters?
Been a long time but I think I used to get them with an MSD HEI kit?
I can look and see if I have one.
Jeff, are you talking about a diode?
I'm not an expert but it a type of resistance wire that was included to correct tachs
Oh ok. Maybe you could snap a pic of it if you find it.
Easy fix, will need to be recalibrated. Anyone with a square wave generator with the proper dwell and an accurate frequency counter can do this
Sent from my SM-T817V using Tapatalk |
Don't hook it up "direct to coil". The MSD kicks out 480V to the coil.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
#38
How do you calibrate it ?
#39
I have it pluged into the msd ...
#40
Charles what ucu are you using? Will it send a tach out signal? If so there should be settings that tell the tach out your firing four cylinders.
'65 Tempest 467 3650# 11.30@120.31 |
