Old 06-01-2020, 07:42 PM
charlie66's Avatar
Originally Posted by Scott65 View Post
Charles what ucu are you using? Will it send a tach out signal? If so there should be settings that tell the tach out your firing four cylinders.
What is a ucu?
My Half AN Injun.....
  #42
Old 06-01-2020, 07:49 PM
73 TRANSAM 73 TRANSAM is offline
Charlie,
I think he meant ECU.
  #43
Old 06-01-2020, 08:04 PM
charlie66's Avatar
My ecu is Fast XFI 2.0
Thanks Ed.
  #44
Old 06-01-2020, 08:20 PM
Scott65's Avatar
Scott65 Scott65 is offline
Yes, ecu, sorry... I'm not familiar with that system. Maybe PM Lee Atkinson. He's a FAST dealer and works with it.
Maybe this will give you a direction to look. https://www.yellowbullet.com/threads...ngine.1564626/
  #45
Old 06-01-2020, 08:31 PM
charlie66's Avatar
I bought a little device that converts the tach to work with 4 cylinders. Ill be getting it tomorrow. The tach cant work with a 4 cyl. Its a old 8 cyl tach.
  #46
Old 06-01-2020, 08:34 PM
Scott65's Avatar
That's cool. There's some pretty serious magic inside some of these ecu's.... I was envisioning the possibility of a programmable output at 2x engine speed or something of the sort. Hope your adapter does the trick.
  #47
Old 06-01-2020, 08:36 PM
charlie66's Avatar
I hope so .
But i broke the car yesterday so thats on hold until i fix the car.
Theres always something ..
Thanks..
  #48
Old 06-01-2020, 08:40 PM
Scott65's Avatar
Originally Posted by charlie66 View Post
I hope so .
Thanks..
Uh oh... Sorry to hear that. Did you get your suspension sorted before it broke?
  #49
Old 06-01-2020, 08:42 PM
charlie66's Avatar
Thanks.
No i didnt.
  #50
Old 06-02-2020, 12:16 PM
70GS455 70GS455 is offline
How do you calibrate it ?
There will be an adjustment potentiometer inside. If not, they are easy enough to add. Soldering and electrical circuit skills are needed.
For the input signal, V8s are 15 rpm per hz and a 4 cyl is 30 rpm per Hz.
If using 55 to 60 deg dwell, set the function generator for 65% negative dwell. 12v square wave output.
Using the frequency counter, adjust the generator frequency using the scaling above. Adjust the potentiometer to get the proper rpm readings.
May have to replace the charge pump capacitor in the tach with a different value but that is easy enough.
Sent from my SM-T817V using Tapatalk
  #51
Old 06-02-2020, 08:44 PM
charlie66's Avatar
Haha . easy for you to say..
I have no idea what you just said.. lol
What is a function generator?
Thank you
  #52
Old 06-03-2020, 11:51 AM
Thank you
I have all that equipment as I repair tachs. May want to send it to someone who dies that type of work
  #53
Old 06-03-2020, 05:54 PM
charlie66's Avatar
That explains it .
Sounds like you know your tachs..
I bought a tachometer converter. But now im having trouble understanding how to set it up..
  #54
Old 06-04-2020, 02:45 PM
That explains it .
What do the instructions say? Should just go inline with the coil- wire, there may be a power and ground too
  #55
Old 06-19-2020, 07:38 AM
charlie66's Avatar
Sorry i havent been on for a while .
I got it all working .
That widgit thing worked great..
  #56
Old 06-19-2020, 12:28 PM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
Charlie, good to know the Widget works as described by the manufacturer.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #57
Old 06-19-2020, 02:40 PM
charlie66's Avatar
Yeah it was easy .
Theres alot of options for other tachs as well.
Thanks for the link Man! Much appreciated!
