Torque converter bolt size
I dropped the pan on the TH400 in my 68 Firebird this past weekend to change the filter and fluid. While under the car I went to check the torque converter bolts using a 9/16" wrench. That was too small so I tried a 5/8". That was too big. I tried a 15mm and it fit perfect. The bolts were tight so I didn't pull any out to look at them. I'm stumped on this one. Any ideas on why they were metric heads? Are the any aftermarket converters that take metric bolts? Thanks
Yes, pretty common to have metric bolts in aftermarket torque convertors. Just installed a Hughes last week in a customer's car. Bolts took a 15mm wrench.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Just an FYI on converter bolts...10mm and 3/8 coarse bolts have the exact same tread pitch. A 3/8 bolt WILL screw into a 10mm hole, but obviously not the opposite. If you use a 3/8 in a 10mm hole and tighten it up, could be a problem...
A THM 400 converter has a 2" line under the pad if it uses Metric threads
