Old 09-23-2020, 09:12 PM
cnc's Avatar
cnc cnc is offline
Default Fender Emblem Bird
Looking for input on the Aftermarket Fender Birds if anyone has purchased them . I have no Idea what NOS ones are worth or even available.... but if someone has a set ????Lmk what’s available or input ...thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-24-2020, 01:06 PM
The aftermarket ones are a peel and stick. I recently found 2 NOS ones on ebay for my '73. They were advertised as sail panel emblems but had the correct pin locations for my fenders.
1974 Formula 400 - Ram Air automatic
Old 09-24-2020, 05:06 PM
Formulabruce's Avatar
GM actually produced these in peal and stick in the 80's as replacement parts. There are NOS ones floating around .
Old 09-25-2020, 07:51 PM
The later 2nd gen sail panel emblems are peel and stick.
I had a hard time finding the correct fender birds for my 73.
Old 09-25-2020, 08:20 PM
cnc's Avatar
cnc cnc is offline
From what I've seen the aftermarket ones have a stud for mounting on the fender if u wanted to use on the sail panel they tell to remove the stud and use adhesive tape
Old 09-26-2020, 10:01 AM
78w72 78w72 is offline
another big difference from the original emblems & even the gm replacements in the 80's is that the originals had some "topography" in the metal of the emblem with raised lines & grooves, then was painted & filled with a thick clear epoxy type material. the gm peel & stick replacements & repro's were more of a printed style in the colored area of the bird.
not sure what the reproductions are like since i had some GM peel & sticks i used but i have a bunch of the original style where the thick clear releases & falls out leaving the chrome metal with the lines. kind of like whats pictured here, original emblem on the left & the repro or even the GM peel & stick looks like whats on the right.
http://www.78ta.com/Pages/nos.htm
Old 09-28-2020, 01:26 PM
unruhjonny's Avatar
/\ I believe that change over was for 1977, but I could be wrong.
I had collected examples of both styles when I had my brother's '73 Formula, but when I gave it back, I gave him those parts too.
1970 Formula 400
