Old 06-18-2016, 09:26 PM
Default When did Pontiac start shipping T/As with honeycombs in 1971?
I was sorting out some wheels and found a 8 27 dated 1971 honeycomb wheel. The code stamped into the rear outer lip read MI-0 and 8 27 KP. I didn't think the honeycombs were available until around the start of the year.
I have a set of wheels taken off a 71 T/A dated MI-0 11 30 with the spare dated 12 14, all with KP stamped. That fits with when I thought the wheels were first available.
For those of you with honeycombs on your cars, what are your build dates?
Mike
Old 10-04-2020, 01:27 PM
JAL71TA JAL71TA is offline
Default Honeycomb wheel question
I realize this is a very old thread but I am looking for some help. I have a set of honeycomb wheels that have M1 5 12 on the back side of the rim. I cannot find any other numbers. Any clue how to decode this? These are on my 71 TA.
Old 10-04-2020, 03:15 PM
Missing a digit possibly?
Check this out:
Rally Date Codes
Should apply to the Honeycombs I believe.
If the '1' is below the 'M' the date is May 12th 1971
Old 10-04-2020, 04:10 PM
thanks for the reply...took a pic and it looks like there is a number or letter below the M1---either a G or 6. Still cannot locate the letter code.
I know on the Rally's its on the outer rim and is easier to see. I'll keep looking but so far nothing. Could the letter code be where I need to dismount the tire? I doubt it would be in the front of the rim since its polycast.
Old 10-04-2020, 04:43 PM
Can you post the pic?
Old 10-04-2020, 08:12 PM
I will give it a shot!
Old 10-04-2020, 09:16 PM
Just TA's or Firebirds in general? Always find it odd that every single Camaro is not referred to as a Z-28.
Old 10-05-2020, 06:40 AM
JAL, you can send the pic to me and I can post it if you want.
johnta1@wallaceracing.com
Old 10-05-2020, 09:37 AM
starlightblack's Avatar
starlightblack starlightblack is offline
If the 6 is below the MI then it is a 1976 wheel
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
Old 10-05-2020, 09:24 PM
Email sent===couldnt post it so it has to be user error!
Old 10-05-2020, 10:20 PM
Does look like a 1976 date.
(May 12th 1976?)
