Old 03-16-2020, 03:32 PM
455TA's Avatar
455TA 455TA is offline
Originally Posted by ErikW View Post
Yes, they did fit with the engine in the factory location. The only interference point was on the block itself. We had to grind the block a small amount where the header just touched it. (picture is just for illustration, not the actual block)
Perfect, thank you! I have the same set for my 2nd gen but haven't started the build yet.
1980 Trans Am - Street/Strip 462
Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas.
Admin of Pure Pontiac Powered Outlaws on Facebook.
  #42
Old 03-16-2020, 03:45 PM
Mark G Mark G is offline
Stainless Headers Manufacturing Inc.
https://www.stainlessheaders.com/pro..._Turbo_Header/
Thank You
  #43
Old 03-17-2020, 07:50 PM
brad cox's Avatar
brad cox brad cox is offline
Looking good Erik! Just curious what are your plans for mounting the leaf springs?
  #44
Old 03-18-2020, 09:08 AM
ErikW's Avatar
ErikW ErikW is offline
Leaf spring buckets will attach to the dropped x-member. We have some really nice adjustable ( multiple holes) heavy wall buckets. They will be braced into the cage also. Then the factory rear frame rails will be boxed and tied into the chassis as well. Stay tuned, that part is coming.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
  #45
Old 03-18-2020, 09:13 AM
ErikW's Avatar
Leaf spring buckets
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #46
Old 03-18-2020, 09:20 AM
brad cox's Avatar
Very nice, looks like you are on the right track for a very fast ride!
  #47
Old 03-19-2020, 07:03 PM
ErikW's Avatar
Default More Progress
The cage is starting to get crowded! Nick adding more tubes. I take my shot at skinning the doors. Not as hard as I thought it might be. Took the holesaw to the door shell while I had it apart to do a little "swiss cheese" treatment. Trying to lighten up this old girl.
ID:	534780   Click image for larger version
ID:	534781   Click image for larger version
ID:	534782   Click image for larger version
ID:	534783   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #48
Old 03-20-2020, 06:55 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
I knew you guys had skills but watching this thread is great!
Looking forward to the watching this progress.
Mitch Kunath
  #49
Old 03-20-2020, 04:21 PM
ErikW's Avatar
Stay tuned, we should get a bunch done this weekend!
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #50
Old 03-25-2020, 02:56 PM
ErikW's Avatar
Got the passenger door skinned and tore down the door hinges for new pins and bushings. I'm also going to put lighter springs in them to offset the new light weight doors. I found that 4L80E accumulator springs fit the bill nicely.
ID:	535324   Click image for larger version
ID:	535325   Click image for larger version
ID:	535326   Click image for larger version
ID:	535327   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #51
Old 03-25-2020, 03:01 PM
ErikW's Avatar
Also got a few deliveries. Our Glasstek hood and Stinger Fiberglass front bumper came in! So now we are just waiting on VFN to finish the rear bumper and dash.
ID:	535329   Click image for larger version
ID:	535330   Click image for larger version
ID:	535331   Click image for larger version
ID:	535332   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #52
Old 03-25-2020, 03:05 PM
ErikW's Avatar
Nick got most of the final welding done on the main section of the cage and dropped it down to fully weld all of the bars at the top. Once it goes back up it will be final welded to the rockers and tied in to the front and rear subframes.
ID:	535334   Click image for larger version
ID:	535335   Click image for larger version
ID:	535336   Click image for larger version
ID:	535337   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #53
Old 03-29-2020, 07:18 PM
ErikW's Avatar
Default Progress
Nick got the cage back in and fully welded to the rockers. Started on forward leaf spring mounts and rear frame tie in. I started removing the old LH quarter panel.
ID:	535717   Click image for larger version
ID:	535718   Click image for larger version
ID:	535719   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #54
Old 03-29-2020, 07:26 PM
ErikW's Avatar
Default Progress
Finally got a "good news" email from Butler that my custom "Turbo" pistons came in from Ross ( 9 weeks). I"ll be seeing them later this week and then I can take the rotating assembly to my guys at Burtonsville Performance Machine and get it balanced.
Got the block out of storage and clearanced the front where the 4.250 stroker crank will hit (400 block). Already had Burtonsville magnaflux, deck & pattern hone the block (4.157 final bore) as well as install oversized dowels and billet center main caps. Can't wait to assemble this beast!
ID:	535726   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #55
Old 03-29-2020, 09:28 PM
JSPONT's Avatar
JSPONT JSPONT is offline
I have Ross pistons in my turbo Pontiac ordered from Butler. Not sure if you got pressed( probably not) but floating pins. They forgot to machine the pin bore. I took them to my local machine shop. Butler did make good on the cost.
  #56
Old 03-30-2020, 07:34 AM
bankbook's Avatar
bankbook bankbook is offline
Thats going to be a bad ass ride when its done.
Want to do another when your done? I'm sure there would be a line. LOL
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #57
Old 03-30-2020, 09:38 AM
ErikW's Avatar
Floating, hope I don't have the same issue but I'll deal with it. Like I said, they have to go to the machine shop anyway.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #58
Old 03-30-2020, 09:44 AM
ErikW's Avatar
Nick and I have sworn to no more projects after this one! Lol. That's what we said about 3 cars ago too He has his pro mod 2000 Trans Am to finish and the rest of our cars need attention.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #59
Old 04-03-2020, 08:56 PM
ErikW's Avatar
More bars! And test fitting sheet metal. Tedious process!
ID:	536319   Click image for larger version
ID:	536320   Click image for larger version
ID:	536321   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #60
Old 04-07-2020, 02:24 PM
ErikW's Avatar
Nick made the through the firewall bars and cut out the trans x-member. Flanged both sides and integrated a driveshaft loop into the x-member. We will be making another x-member for a TH400 also for dedicated drag racing. For Drag Week we have the 4L80E for the overdrive gear.
ID:	536609   Click image for larger version
ID:	536610   Click image for larger version
ID:	536611   Click image for larger version
ID:	536612   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
