Old 04-04-2002, 06:31 PM
vidguy's Avatar
vidguy vidguy is offline
When using the FelPro Metal Gaskets Paul sends with the Ram Air Manifolds, which side does the metal raised ridge that surrounds the ports face? Ridge out towards the manifold or in to the head? Should I use any sealer with these? The head's surfaces are very clean and flat as best I can tell.
Thanks!
James
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
vidguy's Avatar
Thanks!
James
James
Work
Details here:
Old 04-04-2002, 11:26 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Install them clean, no sealer. The raised ridge around the port dosen't make any difference as it flattens out when you torque down the hardware.
[ April 04, 2002: Message edited by: Robert Williams ]</p>
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 04-05-2002, 11:31 AM
vidguy's Avatar
Thanks a lot!
James
James
Work
Details here:
