Old 02-19-2002, 11:05 PM
bus15241's Avatar
bus15241 bus15241 is offline
I just recieved my new D-port ram air manifolds from ram air restorations. How necessary is it to have them coated? What are my options? I drive the car weekly in the summer. Suggestions? Leave them as is? Or? Thanks for your help. Steve
bus15241's Avatar
Old 02-20-2002, 06:40 AM
jim darlington jim darlington is offline
They will turn rusty on you if you don't coat them . Try Eastwood or POR 15 for exhaust manifold high temp paint .
Man is not complete until he's married , then he is finished !
Old 02-20-2002, 01:11 PM
Old Man Taylor's Avatar
I always sprayed mine with heat paint. I used either flat black or the cast iron looking paint.
Old 02-20-2002, 03:32 PM
Larry Navarro's Avatar
here's what worked best for me.
get every bit of grease off the manifolds using laquer thinner and paint brush. let dry.
then brush on the POR-15 stainless steel "boiler" paint as a base coat, then use the "black velvet" exhaust coating as a finish coat. you wont be disappointed. i believe you can buy the products in pint cans, enough to do a couple of pair of manifolds.
Old 02-21-2002, 01:56 AM
Tim Corcoran's Avatar
On my cast iron RA manifolds I used the Eastwood Stainless Steel Gray high temp paint, comes in pint can, and shot it with a gun. Looks fine and last a long time.
Tim Corcoran
Tim Corcoran
