Old 10-25-2016, 02:47 PM
straycat's Avatar
straycat straycat is offline
Ahh Ray, Lookin good. In the 2nd pic it looks like a small brake pedal and the shifter looks suspiciously manual trans to clear a bench seat. Is there a clutch pedal too? I also answered your PM
  #42
Old 10-31-2016, 08:32 AM
62cat's Avatar
62cat 62cat is offline
Good eye Bob. Its a Hurst autostick shifter behind a t350 reverse manual valve body. Would love to put stick in it. Maybe in a few seasons after i get the bugs out of it.
  #43
Old 11-02-2016, 08:16 AM
62cat's Avatar
Default update
Spool axles and brakes installed. Wheels and tires fit in well perfectly. almost ready for the street/strip.
ID:	439964   Click image for larger version
ID:	439965   Click image for larger version
  #44
Old 12-08-2016, 11:32 AM
62cat's Avatar
Default update
Had it outside for a few shots. Might need to raise it a little.
ID:	442270   Click image for larger version
ID:	442271   Click image for larger version
  #45
Old 12-08-2016, 12:48 PM
Daubert20's Avatar
Daubert20 Daubert20 is offline
Looks great! Nice color combo and wheels and tires.
  #46
Old 12-08-2016, 01:36 PM
Engine-Ear's Avatar
very nice! I want one of those license plates to hang on my garage wall!
  #47
Old 04-04-2017, 12:05 PM
62cat's Avatar
Default Exhaust
A lot has been getting done. Here are some exhaust photos. Its fully welded now this was during mockup. New driveshaft and gauges are installed.
ID:	451460   Click image for larger version
  #48
Old 04-04-2017, 12:40 PM
Engine-Ear's Avatar
Thumbs up
Great progress!!
Quick question: what is the bolt (that's going thru the frame, pointing down) doing / for?
  #49
Old 04-05-2017, 07:05 AM
brut4s's Avatar
brut4s brut4s is offline
What size tires and wheels are you running? Did you modify the rear and?
  #50
Old 04-05-2017, 09:49 AM
62cat's Avatar
Originally Posted by Engine-Ear View Post
Great progress!!
One of the mounts for the braided fuel lines.
  #51
Old 04-05-2017, 09:54 AM
62cat's Avatar
275/60/15s No narrowing of rear. Mark Williams axles and spool. 15x8 weld truck wheels that are powder coated. Have to trim lip a little and might have to modify frame a bit. There is a 1/4 inch clearance on both sides.
  #52
Old 04-05-2017, 12:42 PM
Engine-Ear's Avatar
Question required tire-to-wheel opening / frame clearance
Correct me if I am all wet here, but here's what I'm thinking: as the tire spins, it gets taller (right?) and the bottom of the tire (that is supporting the car) is what gets wider, but there's no obstruction there.
How much gap (at the top of the tire) is needed?
  #53
Old 04-06-2017, 04:30 AM
brut4s's Avatar
That's a decent sized tire. i didn't think there was that much room.
  #54
Old 04-06-2017, 02:24 PM
Tim Younker Tim Younker is offline
Great color combination. Good Luck with the completion. Get it out every chance you have.
  #55
Old 11-13-2017, 08:06 PM
62cat's Avatar
Default progress
Went out for roll bar then for upholstery. A couple weeks work and it will be out spring 18.
  #56
Old 11-13-2017, 08:45 PM
74 SD455 Formula 74 SD455 Formula is offline
Love what you have done to your car. I have a 61 Post car that I took off of the track and am now putting back on the street. I have a 472ci ( 455 ) Kaufman heads to keep the look of a SD. I hope to have mine back on the street by next year. I am planning on going to the POCI and I'm driving it there.
  #57
Old 11-13-2017, 11:10 PM
Stuart's Avatar
Stuart Stuart is offline
I lik it. You just don't see very many two door post '61s, and they look especially good in black.
  #58
Old 11-13-2017, 11:37 PM
U47 U47 is offline
Nice car, you are a lot further along than I am with my 62 post. My build is for Grand Touring ( road racing and street time. Suspension is now done and body work started.
  #59
Old 02-13-2020, 12:28 PM
62cat's Avatar
Default Little update
Changed over to race bullets on the exhaust the Flowmasters were not working with the evac system. A recent Pic also.
ID:	531809   Click image for larger version
ID:	531810   Click image for larger version
  #60
Old 02-13-2020, 04:20 PM
3fastgtos 3fastgtos is offline
Love your car, have fun with it.
