Tack rag on base coat?
For the painters here. Do you guys use tack rags after spraying base to get the overspray dust off or go ahead and spray clear without touching? I remember using a tack rag on a paint job and causing light scratches.
I dont touch it at all, unless your having an issue with dry spray there should be no need in my experience.
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
I'm one who tacks between coats on an all over or a blend. Just be sure you allow plenty of time for each coat to dry and use a low tack style over base. I use the Specialty brand (PPG) blue rags. Not too gummy and don't streak.
YMMV. |
The Following User Says Thank You to 400 4spd. For This Useful Post: | ||
Hey 4004spd, I tried it once on metallic base & it felt like it was catching on the metallic particles. Would you have any suggestions? 1. I am an inexperienced painter. 2. I was using the standard old style tack rag. Your help would be welcome. Thanks Murf Sent from my iPhone using Tapatalk Pro |
I inspect and then clear without touching. My thought process is that any potential light layer of overspray will reactivate and flow out nicely. Seems to work okay for me.
Thanks. I have done it both ways. Not sure if one way was better. My thought was overspray or dust doesn't stick, so does the clear have a hard time bonding as well. Then, I have noticed fine scratches from the tan tack cloth. I felt this was causing more problems than it was worth.
Yup....like 400 spd....I tack off in between coats..and use the not so sticky Gerson Basecoat tack rags. If you can tack it...you can whack it.
