Old 04-09-2023, 09:57 PM
SD421's Avatar
SD421 SD421 is offline
Default Placement of Speedometer Cable Grommet
Hi anyone,
Which side of the grommet installs inside the interior?
The wider or thinner side ?
This is how I installed it but it’s been years since I had the speedo cable installed.
And I can’t find my GTO Restoration Guide
Thanks,
Don
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 04-11-2023, 10:53 AM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
Cannot guarantee this is correct, done by Previous Owner when he converted car to 4 speed, but this is how the grommet looks from interior in mine.
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
The Following User Says Thank You to ftwmlp For This Useful Post:
Old 04-11-2023, 12:07 PM
SD421's Avatar
Awesome! Thank you Ftwmlp
1966 GTO
1966 Tri-Power
1967 670 Heads
