Old 04-26-2023, 06:05 PM
gtorich gtorich is offline
Default fuel pump
Sorry for the stupid post, i bought a pump few years back, was supposed to only have 4-5 lbs fuel pressure for my tripower, of course i cant find any paperwork on it............so what are you guys using for a 66 with tripower for the fuel pump.
Brand and numbers would be great.
If it helps any, i heard you could have 3/8 hole on the mounting holes, mine are 5/16
Rich
Old 04-26-2023, 10:47 PM
Some timing cover have 3/8 and some 5/16. If pump has 3/8 it will work on either.
Old 04-27-2023, 08:51 AM
Thanks Goatracer...........i double checked mine i have the 5/16 holes, was looking at the delco 40373........seems backordered most places, the other one is a carter M 4507.....as i said i cant remember what i have, but its at least 7-8 yrs old, thought since everything else is new, might as well get that.
Rich
Old 04-27-2023, 12:07 PM
Rock Auto has the Carter for $16.40. if you are interested discount code of : 229357924208978840 is good until May 19, 2023.
Old 04-27-2023, 02:06 PM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
I purchased the Carter M4507 for my 66 389 with AFB. Installed and used to break in engine on run stand, but no actual street use at this time.
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
Old 04-27-2023, 03:48 PM
Thanks Goatracer, now were talking about that price................i usually roll with the "Buy high, sell Low..........will get that one.
Rich
Old 04-27-2023, 04:43 PM
madeuce50's Avatar
madeuce50 madeuce50 is offline
For what it's worth......
The Carter M4507 pump is rated at 6 to 6.5 psi, some folks would say a bit high for tri power set-ups.
Old 04-27-2023, 06:04 PM
Thats why i asked my original question...........i cant find the number for the one i ordered, but thought it was at 5 psi at the highest.............never had any issues with that one.....................im just wondering if i should just use that pump even though it has a few years on it...........
Rich
Old 04-28-2023, 04:53 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
NOS GM... https://www.ebay.com/itm/314535520762
Old 04-29-2023, 04:22 PM
If it's NOS the diaphragm will be old and possibly dried out. Also it won't be compatible with today's gasoline with alcohol in it.
Old 04-29-2023, 09:24 PM
wbnapier wbnapier is offline
I have my tripower at 3.5 psi.
I use a regulator I bought at PontiacTripower.com
https://pontiactripower.com/products...431642e8&_ss=r
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 04-29-2023, 10:05 PM
428ho4spd's Avatar
I've been using NOS pumps for years without any issues. I would much rather take my chances with NOS over the new crap they're selling today. And you'll know the pressure is correct, problem solved.
Old 04-29-2023, 10:41 PM
You know nothing about a 50 year old pump until it fills your crankcase with gas.
Old 04-30-2023, 12:04 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
This is the NOS fuel pump I installed in 1991 on my ‘66 GTO that I had just purchased.
Ran perfect then and still runs perfect.
I have another boxed 40373 on the shelf, as you can’t beat an OEM part.
Just sayin.
Old 04-30-2023, 09:50 PM
A fuel pump that old was NOT designed for today's alcohol diluted fuel so even if it's parts were still good when you installed it they will fail.
Old 05-01-2023, 06:10 PM
lust4speed's Avatar
If you use an old NOS pump make sure your insurance is up to date.
I would run a pressure test after installing any fuel pump.
Mick Batson
