Old 05-31-2020, 09:31 PM
Default 26 spline input shaft For Clutch tool
I seem to have misplaced or loaned out my 26 spline input shaft I use on
Pressure Plate/Clutch Installations.
Anyone have a 26 spline Input Shaft from a trans that I can buy for use as a clutch tool.
Thanks Tom V.
Old 06-01-2020, 09:07 PM
Working on a deal to Borrow a Fine Spline Muncie Input Shaft but I am still interested in acquiring one for myself to use permanently.
Old 06-01-2020, 09:15 PM
Tom, are you against using one of the thick plastic 26 spline clutch disc line tools? Bought one years ago & it has worked well.
Old 06-02-2020, 09:55 AM
"Years ago", parts might work if I can not find a proper input shaft to locate the disc properly for the installation. The chinese new stuff out there obviously is worthless.
I have a "possible" for the 26 spline input shaft to borrow locally.
I will see if that works out first.
NEVER LOAN OUT YOUR TOOLS is typically a safe bet but I still do it occasionally.
Old 06-02-2020, 11:08 AM
chrisp chrisp is offline
The plastic tool is fine , remove it slide trans in & have someone depress the clutch pedal & you are done.
Old 06-02-2020, 11:28 AM
tom s tom s is offline
They suck compared to a input shaft IMO!Tom
Old 06-03-2020, 03:03 PM
Like some people!
Old 06-07-2020, 06:05 PM
younggto younggto is offline
I’ve had good luck with the Ram tool; only about $50.
Old 06-07-2020, 08:15 PM
BB70's Avatar
BB70 BB70 is offline
X2 on the Ram alignment tool.
Old 06-08-2020, 02:03 AM
CatalinaMike CatalinaMike is offline
For an idiot who is not positive what it looks like I have a box of transmission shafts and yokes. Happen to have a pic or dimensions?
Old 06-09-2020, 01:15 PM
Old Goat Racer's Avatar
This
Everybody knows somthin.
Nobody knows everything !
Old 06-09-2020, 01:17 PM
Thanks Tom V.
This guy mite have a broken gear ?
https://www.superpages.com/bp/s-milw...2200051978.htm
Old 06-11-2020, 06:06 PM
No luck. The only one I have close is 22 spline
Old 06-11-2020, 10:57 PM
Info from here: http://www.superchevy.com/how-to/tra...-transmissions
Input Shaft Identification
Years Type Grooves Input Shaft Splines Output Tooth Count Output Shaft Splines
1963-’65 M20 None 10 24 27
1966-’70 M20 Two 10 21 27
1970-’74 M20 Two 26 21 32
1963-’70 M21 One 10 26 27
1970-’74 M21 One 26 26 32
1967-’70 M22 None 10 26 27
1969-’74 M22 None 26 26 32
So I am looking for a 26 spline input shaft for a 1970-1974 M20 Trans or a 1970-1974 M21 Trans, or a 1969-1974 M22 trans.
The key is the 26 spline version vs the typical 10 spline GTO type Muncie Trans.
Old 06-12-2020, 06:17 AM
'72 models were last factory installed M22's.
Input shaft from '2nd design BW T-10 (74 1/2 on) would also work.
