Old 05-26-2016, 01:15 AM
c.w. fields c.w. fields is offline
Default 1975 Pontiac Grand Am Courtesy Lights
When I step on the brakes the courtesy lights come on. The dome light with the two map lights on the side lights up in the middle dome when I step on the brakes. At first it was just the dome and now the two in the floor console come on. The headlight switch only turns on the two console lights and not the dome light. The map lights also do not work and I am sure the bulbs are good. At night this is quite annoying as I can be sitting at a light with the dome light illuminating me. Any help or suggestions would be helpful as I have a service manual but can't seem to resolve this. Thanks, CW
Old 05-26-2016, 06:25 AM
Pepi's Avatar
Pepi Pepi is offline
Sounds like a bad ground, or improper bulb in the tail lights somewhere. have you done anything lately to the car?
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 05-26-2016, 09:25 AM
X2!
Usually when the brakes make a light come on it is from grounding.
The brake pedal rod moves and makes a better/worse ground to the dash area.
(or check to make sure the rod isn't wearing through a wire?)
The bulb idea is good too, if one of the filaments breaks and falls against the other (or ground) it will provide power to the other circuit.
Lots of strange things can happen with electricity.
Old 05-26-2016, 10:33 AM
Check your fuses, especially stop light and tail light. Not just look good but make sure there's power on both ends where the fuse snaps in.
If not a blown fuse, then look for rub through on one of the courtesy/dome light, white wires, in the brake pedal area.
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 05-26-2016, 12:20 PM
Default 1975 Pontiac Grand Am Courtesy Light issue
Thanks for the replies. I have done a lot to this car lately but all this was going on before I changed out the aftermarket radio to the original am/fm stereo, replaced front dash speaker, changed out intermittent wiper dash switch and worked on lower dash ac vents. I am stumped as to why the map lights stopped working and the headlight switch doesn't turn on the dome light and I will continue to check all the issues mentioned. Thanks again,
CW
Old 05-28-2016, 06:34 PM
After reading the service manual for this car and doing some testing I thought I would post an update so if anyone else had a problem like this they would know how to correct it. It seemed a complicated electrical issue and turned out quite simple. Along with the other problems the hazard flashers did not work. I went through a few that I had in a box and found a flasher that was good and now they work. Along with that all the other issues went away. The dome light works as normal along with the map lights. No dome light on with the brake depressed. Can you believe it was that simple. Again thanks for everyone that posted.
CW
Old 05-28-2016, 07:14 PM
Pepi's Avatar
Congratulations on the fix, glad it was a simple one.
