Upper radiator hose for ‘67 GTO HO
Is there a difference in this hose if You have or not have power steering?
Yes
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
Link to Rock Auto listings for upper radiator hose W/, and W/O power steering:
https://www.rockauto.com/en/catalog/...pper+hose,2058 |
Radiator hose correct?
Please have a look at the photo. This goat has manual steering, but to me the hose is wrong and the should be wrapping around to the outside of the alternator. Or is that only the case if you have power steering?
Good lord that's a long bracket!
It appears the bracket is incorrect...that does make sense,
That isn't what he said. The OEM bracket is crazy long. Doesn't matter how many
times I see it, that's always what I think. But it is how they were built. |
1967 with manual steering.
Yes, long alternator brace.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
Actually I did mean that the arm is much longer than what I have on my '67 GTO's, but they both have power steering. The pictured non-PS bracket places the alternator about half a width past the centerline of the valve cover and mine are half a width towards the centerline of the engine. Didn't know the brackets changed along with the options. I was thinking the long bracket was probably for a later engine. That would explain why there are two different top hoses available.
Here's three shots that I could find showing the stock bracket with PS.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. Last edited by lust4speed; 07-23-2020 at 01:28 AM. |
Bracket
Not sure about the length of the bracket but I did learn manual steering only has one bracket, power steering has two brackets.
(picture is example with two brackets) |
Manual steering alt bracket is very long.
BRACE
All 64-67 use the long alternator support “Brace” for manual steering.
These are black painted steel. On all power steering cars (64-67) there are two shorter “Braces” for support and adjustment. The alternator “Bracket” is what bolts to the LH cylinder head to support the weight of the alternator. These are cast or aluminum. CT.
Interesting. I was not aware that there was a difference between power and manual steering. Apparently I've had the wrong upper hose on my manual steering 66 GTO for 30+ years!
Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am |
