Primng the engine after new cam installation
I want to circulate some oil in my engine before I do the initial start up after installing a new cam. I don't have a spare distributor to strip and use as the drive mechanism. Any ideas what I can do to make a drive mechanism.
I also posted this in the "street" section. |
Need to buy a primer shaft
It’s made by Moroso |
I'm only going to use it once for about 5 minutes. I think I would like to build something brcause I need it Monday.
They are about 20 bucks and any speed shop or auto parts store should have it
If not Amazon prime will have it to you in a day |
I just ordered the pump primer fron a local parts store. It should be in Tues. morning. The first ones that I looked at online were ~$50 , way too much but this was $24, much better.
When priming, get the oil flowing, then rotate the crank by hand 1/4 turn and prime again. Rotate the crank 1/4 turn each time you get oil flowing until you have turned the crank 1 complete rotation. This ensures everything gets oil and any trapped air is pushed out.
Don't forget, counter clockwise.
No need to do anything of the such > http://forums.maxperformanceinc.com/...d.php?t=842717
I was refering to the primeing tool.
