cam retainer
in screaming sheifs pic here, is this side on the top the side that goes towards the cam? thanks.
I no longer have that beautiful 66 in my Avatar. whaaa! When a cat is dropped it always lands on its feet. When buttered toast is dropped it always lands with the buttered side facing down. If a piece of buttered toast was attached to the back of a cat, when dropped, the cat/buttered toast combination should hover, spinning just above the ground, as it tries unsuccessfully to resolve the inevitable conflict of non-scientific certainties. |
Yes,that is the block (cam) side.
That hole/slot connects to the front cam bearing journal area and that is supposed to lube the timing chain. HTH Bret P. |
And the slot is on the lower portion when installed correctly. The one pictured has quite a bit of wear, and I usually replace them when they reach that point. The plate is flat when new, and the thickness of the plate determines fore/aft movement of the cam gear. Thinner plate means more movement - and that means quicker timing chain wear.
hmm. ok, i guess i need to check for i think .007 end play then? hate to spend $20 on a small piece of anything. well, almost anything thanks sc and L4s
And boy, does that slot dump a lot of oil on the t-chain!
Agree with L4S, that plate is worn out and should be replaced.
lol
Dittos. I've thrown away better looking ones. Considering how important its job is, $20 for a new cam thrust plate is CHEAP insurance.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
Ya know it sure looks like that plate was machined like that. If the cam did that then it must have had the carbide tip option. If you get less than. 003 " end play then you need to make the plate thinner to gain the clearance. Or machine it like that might be another way to do it. 1st for me :/
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
On my first build, The kid that put the timing chain on used a hammer and put a bur on the timing sprocket which caused it to sit out to far which set the end play at around .050. It beat the camtrust plate like that in the photo in less than 100 miles. Charles
got a pm offering one up for $10 i guess i need one.the edges of mine were rough, almost beat up, so i filed them. ended up smoothing the top so there is no edge. dont think there was one there before anyway. then put on flat surface with 200 grit. it doesnt seem like it sat flat as there in no lip on top and just barely any on the sides.
