Old 11-23-2019, 09:00 PM
Goatboyjohnny Goatboyjohnny is offline
Default 400 yoke
Ok gang, I posted in the wanted listings, but maybe someone here can help. I've been through 2 brand new yokes already. My issue is not overall length, it is the distance from the centerline line of the U-joint bore, to the back end of the barrel. Does anyone have a part number for an exact replacement part ? Any help is greatly appreciated.
Johnny
Old 11-23-2019, 09:04 PM
Here are pics of the damaged original I am trying to replace.
Old 11-23-2019, 09:08 PM
Try those again...
ID:	525239   Click image for larger version
ID:	525240   Click image for larger version
Old 11-23-2019, 09:22 PM
ponyakr's Avatar
ponyakr ponyakr is offline
As posted on the other thread, this Neapco looks real close, to me.
https://www.dennysdriveshaft.com/p10..._inside_c.html
The Spicer yoke does not resemble a GM factory usage T400 yoke, appears to be a very HD aftermarket piece, most likely originally engineered for a rock crawler build. At one time I had identified 11 different '65-late 70's GM T400 yokes from actual, hands on pulling each & every one of them. Of those 11 different styles, not including bolt on style yokes, there were 4 different lengths.
What driveshaft you trying to fit with a T400 yoke? If a stock length T400 driveshaft, can most likely point you to the original length of T400 yoke that was used.
Old 11-23-2019, 09:25 PM
Hmmmm... Pictures just loaded.
Appears to be an example of what was the common '67-74 med length T400 yoke.
Are the splines all the way to the end inside, or recessed back nearly an 1"?
Old 11-23-2019, 09:26 PM
Yakr, that neapco does look very close, thank you. OPH, I am installing a super T-10 with the driveshaft of a muncie equipt car. Thank you both again.
Old 11-23-2019, 09:28 PM
What year & bodystyle car?
Old 11-23-2019, 09:30 PM
No recess. Also just realized it has a groove for outside snap ring, but it is too messed up to use anyway.
ID:	525249   Click image for larger version
66 GTO Hardtop.
Old 11-23-2019, 09:42 PM
Would expect the driveshaft to measure 59 1/4- 59 3/8" center to center on 3R ujoints to use the common medium length BOP T400 yoke with a Second Design T-10.
Old 11-23-2019, 09:47 PM
Does the pictured yoke appear to be the common medium length yoke you're speaking of?
Old 11-23-2019, 09:52 PM
Old 11-23-2019, 09:56 PM
Appears to be, I also have, in a car, the same machined length version that the splines are recessed.
Old 11-23-2019, 10:00 PM
Thank you sir!
Old 11-27-2019, 08:47 PM
Well the Neapco yoke looks pretty close. I probably won't get to try until Friday, I'll keep you all posted🤞
ID:	525570   Click image for larger version
ID:	525571   Click image for larger version
ID:	525572   Click image for larger version
