Old 11-25-2019, 12:20 AM
gto19's Avatar
gto19 gto19 is offline
Default 67 gto master cylinder
I was cleaning the firewall this weekend...someone had spray painted some of areas with black paint including the master cylinder . I’ve been able to clean a lot of it up . While cleaning I found this sticker on the back side of the master cylinder and cleaned it and moved it forward to take a picture. Anyone know what it means or if it’s original?
Old 11-26-2019, 12:33 AM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
It looks like an original tag. The "RK" code designates that particular master cylinder to be installed on the car at the factory per the build order.
Very cool!
Old 11-26-2019, 12:48 AM
gto19's Avatar
What a trip how a sticker can last that long !! Now what’s the RK stand for ?
Old 11-26-2019, 01:22 AM
428ho4spd's Avatar
If they don't get wet or blasted with a hose over the years, they can survive. Basically, its just a part code tag for that particular part to go on your car per the build.
Here's some photos of the casting date and part number of the master cyl on my car. Take photos of yours from underneath the master cyl and see if its the same number and dated correct for your car.
ID:	525448   Click image for larger version
Old 11-27-2019, 07:24 PM
geeteeohguy's Avatar
That honestly looks like the original master cylinder, which is amazing. I think I've replaced the master cylinder 3 times on my own '67 in the past 36 years! Amazing for one to last 52+ years!
Jeff
Old 11-27-2019, 07:35 PM
gto19's Avatar
It is the original. The part number is cast under neath . The cast date code is very hard to read though...crappy sand casting . The only major component I’ve found not original is the waterpump ....
Old 11-27-2019, 09:32 PM
Scott Thelander's Avatar
thats crazy ....
just the other day it happened to me too on a 69 I am parting out ...
pulled the manual brake master thinkin it wasnt an original because it had no bleeders..
and
it had a tag also ...
yup its an original .... hmmmmmmmm
a 70 manual drum brake next to it with bleeders but a different part number,,
it must be the pull code ,,, and on our build sheets ....
mine was petrified by a rats nest of grass and seeds ....
ID:	525577   Click image for larger version
Old 11-27-2019, 09:48 PM
gto19's Avatar
Wow ! That’s cool . That’s the same looking tag as on my master cylinder!!
Old 11-27-2019, 09:59 PM
242177P's Avatar
242177P 242177P is offline
Originally Posted by Scott Thelander View Post
pulled the master thinkin it wasnt an original because it had no bleeders..
Bleeders weren't used on the manual brake cars (tilted masters trap air inside the bore)
Old 11-27-2019, 10:29 PM
Default hmmm
11 D ...
ID:	525580   Click image for larger version
ID:	525581   Click image for larger version
Old 11-30-2019, 11:13 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
True, at least 67 and older for “Manual Brake” M/C.
On a “Power Brake” unit, the Booster is mounted at a slight uphill which causes the M/C to also be the same, consequently trapping air.
Therefore the need for bleeders on a PB car.
Chris.
