Anyone know someone using ABS brakes relativly new hydro boost?? It's a replacement for the vacuum booster. It uses the hydraulic pressure from your power steering pump to generate the assist. Since I need booster, master cylinder, and combination valve anyway this could make my vacuum concerns meaningless. Total package is around $650.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
got my HydroBoost with MasterCylinder for $11 from a U-Pull-it.
Gotta rebuild it before I R&R the vacuum booster, due to hydro-leakage. Nothing TCS or ABS about it...yet.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
By ABS I meant American Brake and Speed. It's definately not an ABS pices. Where did you find one for $11 in a U-Pull-It ??? Nice find...
from an Olds Diesel car.
in a local U-Pull-it. Guess nobody was looking for it. "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs<br />12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Sounds like I need to do a little hunting for one [img]/infopop/emoticons/icon_smile.gif[/img]
Honest dad, that 455 on the side of the block is a serial number [img]smile.gif[/img]
...my Hydro boost came with the aluminum Master cylinder (frontDisc/RearDrum),and power steering hoses.
There is a vent line from the hydro-boost unit that drains back into the PSpump resivoir...I'm gonna have to add a 3/8 resivoir fitting to my 68 PS pump [img]/infopop/emoticons/icon_mad.gif[/img] H.I. Stud "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Discovered the 76-78 Eldo's had this system also. Since I am using their rear calipers I'm looking for a set up from one. Shouldn't be too difficult. Thanks for the info...
Honest dad, that 455 on the side of the block is a serial number [img]/infopop/emoticons/icon_smile.gif[/img]
SUCCESS!!! Found a complete setup. Booster, master cylinder, and proportioning valve for $40. And local too [img]/infopop/emoticons/icon_smile.gif[/img] Thanks for the tips Half-Inch!!!! [img]/infopop/emoticons/icon_biggrin.gif[/img]
i had low vacuum and my brakes didn't work too well. i got a vacuum pump out of a eurosport chevy classic. forget the year, but it pulls 21" and is fairly small. got it for under 10 bucks. not familiar with hydro but thought id offer my solution to my prob. one question though? if for some reason you throw a belt, do you lose all braking power?
I did a lot of research on Hydra-boost after seeing it on Malcolm MacKellers early prototype
Overhead Cam Pontiac. I knew it was a factory part on diesels and such but did not know how it worked. I work for Ford in Engineering and my 600 hp Pool Car has hydra-boost on it. Fact is ALL MUSTANGS from 1996 on have Hydra-boost on them. I made a simple bracket mod to an existing 67 power brake bracket to match the Ford bolt pattern and adapted a screw thread to the brake pedal instead of the ford round loop type attachment to the brake lever. I was very happy with the hydra-boost on the Ford Mustangs and did not have to rebuild my 2000 model year unit. Tom V.
Poks, yes, if you throw a belt you loose all power assist, but not all braking power. It'll basically revert back to 'manual' brakes, minus the friction/return spring losses in the hydroboost unit.
67 455 Bird ragtop:
disassemble, clean, and reassemble the Hydro-leak unit, so that it doesn't Rust-proof your firewall. I plan to use SILICONE FLUID in liew of any fabric gaskets. Otherwise, I plan to do relief-grinding on mating surfaces to concentrate clamping forces on the sealing areas. Really looking forward to seeing the Driverside firewall for once. H.I. Stud "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Uhm...SILICONE SEALER...not really FLUID for long.
I hope. "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Thanks for all the advice. The Eldo pump mounts a little different from the normal booster. But making a new mounting plate for it will be a snap. Poks idea on the vacuum pump out of the euro chevy sounds like a good fall back plan.
