It is apparent that while setting up my carb I have been a bit careless. I have managed to strip one of the main body squirter threads. Since there are slots through the threads is it repairable or is the main body now junk?
I have seen a few threads and vids of thread repair inserts. Would it be possible to do then somehow recut the slots? Would it be viable to fill the hole with JB Weld, Devcon or another product then drill, tap and cut slots, or is that just silly? I have done drilling and tapping for set screws, but since I have never done a thread repair insert and this one looks tricky I will more likely send the carb out. Frank.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
I don’t have a carb apart to check out, but there might be more undrilled and taped meat at the bottom of that stripped out hole .
If so there might be a chance for you to use a longer machine screw and catch enough new threads to get some ok clamping power.
Picture might help...
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
some high flow squirter screws are hollow, holes drilled all over the place swiss cheese without the swiss or cheese...
if you were to helicoil and obstruct the original fuel path one of these hold down screws might work
.................................................. .No One Ever Escaped Tyranny By Compliance.............................. |
![]() Quote:
I thought about that but it looks like a longer screw would contact the check needle then not allow any fuel to pass. I'll have a closer look and do some measuring. The screws are the hollow type and if I replace it with a non hollow I think I would lose some pump shot.
What kind of a main body is it ?
![]() Mighty Demon 825. I think it's aluminum.
If it's the threads for the squirters, it's a "machining operation", not recommended to DIY. Shaker 455 does them.
The Following User Says Thank You to 65 Lamnas For This Useful Post: | ||
Thread Tools | |
Display Modes | |
