Old 11-11-2019, 07:16 PM
grd777 grd777 is offline
Default found a odd ball alternator
the number on the alt is 1100928 55a
2d6 12v neg
but it seems on the back of it it has a hook up for a external regular
is this correct
Old 11-11-2019, 08:19 PM
steve v's Avatar
steve v steve v is offline
More than likely it went thru a rebuilder at some point in the past & had a different rear section put on it.
Old 11-11-2019, 08:26 PM
yes that is what i thought
what cars and years did the external reg come on
Old 11-11-2019, 08:54 PM
johnta1 johnta1 is online now
The internal regulators started in 1970 for the Firebirds and 1971 for the rest of the models, basically. (some certain apps like 69 400 Birds, could be had before that)
Yours is a 1972 model.
Old 11-12-2019, 01:44 AM
Formulabruce's Avatar
Actually I have bought a couple of the mid 72 "928's" with external regulation as well.
These are NOT a oddball, and many you can find are NOT rebuilt.
These were used on AMC Gremlins with external regulators.. GASP...
Yup, I have removed an original myself. In Fact you can find the 928's up into 1976, and seller will tell you they are from 1966.
You can buy these for 20-30 bucks and rebuild into a 10si, IF you really need that date. I have built a few of them.
Old 11-12-2019, 12:11 PM
Very odd, but nothing surprises me with AMC's sourcing of component parts.
Over the last 30 years, I've easily pulled two dozen '71-74 model 928 alts off original Pontiac 350-455 engines & several dozen more '71 & 72 model usage 928's from used parts stocks & in boneyards, can't remember running across one without a 10SI (internally regulated) rear case.
Old 11-12-2019, 12:18 PM
Believe the earliest Delco oem internally regulated alternator was the "800". Has a specific finned rear case, but not the same as used on the '69 or '70 intenal reg alts. The "800" was the factory alternator on a '68 GrandPrix with AC. Have one out in the alternator boxes.
Old 11-14-2019, 05:40 PM
stellar stellar is offline
AMC didn't use the 928 until 1975 and it was an internally regulated alternator. All 928 were internal. Someone changed the rear case.
Old 11-19-2019, 09:55 PM
There are listings for the 928 in Hollanders in cars with external regulator.
I have seen and own a 76 "928" , and Pontiac wasn't using it.
I guess its possible that the "928" may have had a 7-8 year run when new, regardless of clock position, and vehicle it was installed in.
