Old 04-29-2008, 06:36 PM
Region Warrior's Avatar
Originally Posted by ho428
I posted this awhile back but thought I'd add it here for reference in case anyone wondered what that lump under the hood actually weighs.
Complete 400 engine, iron heads and water pump, but without headers or flywheel attached.
Not that you could run without it, but now you know.
Anyone know what is the wt difference between aluminum heads vs Iron?
Aluminum water pump vs iron?
Aluminum bellhousing vs Scattershield?
I can wiegh fully loaded #16 D-ports(just removed a pair) vs ported E-heads with 2.19/1.66 vlvs(triple vlv springs) without rkr arms for comparison.
And water pumps. Have couple each.
And stock bell housing.
  #42
Old 04-29-2008, 07:45 PM
Pearlbluebird's Avatar
Pearlbluebird Pearlbluebird is offline
It seems high to me but I have it in print here for a 400 car at 3855 for curb weight.
A second class drive is better than a first class walk.
  #43
Old 04-29-2008, 10:11 PM
Firebob's Avatar
Firebob Firebob is offline
Had my full dress 9er weighed a couple of weeks ago. 3740#. 1/4 tk gas, 4sp, SF conn, 4pt bar, traction bars, 150# in the seat.
Robert
  #44
Old 04-30-2008, 01:32 PM
Found my list and wieghed some other stuff laying around last night with a cheap bathroom scale.
Fully loaded #16 hd: 72
Ported 66 cc 2.19/1.66 E-heads/Manley vlvs/triple springs and rkr studs(no rkr's): 30
Uncut stk intake w/switches: 43
Uncut Victor: 18.5
Torker I and II; didnt feel like dig'n out.
std 850 Holley: 13
stk 800 Q-jet: 11
Stk water pump: 7
Aluminum w/p: same reason as above.
19" stk clutch fan: 6.5
19" flex fan(steel ctr w/7 stainless steel blades): received phone call, but think: 4.5
Stk 70-455 air cleaner: 16
14x3" chrome drop base a/clnr: another phone call
Stk exh manifolds: 24
70 RAIII exh mans: Still need to dig out.
1-3/4"-3"(3 bolt collector) Hedmen d-port's: 28
1-7/8-3.5" (coated slip fit collectors) Dougs still in shpg box: 38
Stock GM unpainted fenders: 30 ea.
Steel deck lid: 27
Hood: didnt find note yet.
Glasstek bolt on hood: think i was told 22 shpg wieght? last month.
Cowl, fdrs, doors, deck lid: need to find out.
14X7 ralleys w/225-60 radial(full tread): 44
14X7 " w/245-60 radial(1/8" tread left ): 47
15x5 Weld Stars w/165r15 Coopers(full tread): 27
15x8(or 8.5-9. ?)w/27x11.50-15lt Hoosier QPT(1/8" left ): 27
Frame connectors: 16
Stk tank vs cell: have to find note
Front cowl panel LH/RH "horns" under fenders, and whl/houses: still have find that note
90-91 TA plastic wheel liners: less then a lb. ea.
Same with stock frt seats vs APC cloth seats(in car), and stk seat belts vs 5 pt belts(way heavier).
  #45
Old 04-30-2008, 01:59 PM
Also have th350, th400, 200-4r, 700r4, 4-spd, 9", 10", and stk trq cvrtr's, 1st gen 10 bolt, 2nd gen 10 bolt, and 1st gen 12 bolt rear ends wieghts somewhere.
  #46
Old 09-19-2008, 12:13 AM
Donovan Donovan is offline
Whole front disc brake setup
-spindle
-caliper
-dust shield
-bracket
-cap
-bearings
-hub
-Rotor
45 pounds per side
1969 Single piston style brakes
  #47
Old 11-19-2008, 12:07 PM
Bring'n this back up cause the inner bracing(center only) fell out of the hood last night
6 lbs.
The cowl "horns" look like they'r gon'a fall off this winter also.
I'll post when they do.
  #48
Old 11-19-2008, 12:54 PM
JoePapa's Avatar
JoePapa JoePapa is offline
This was pretty accurate for my year:
1967 AMA Spec's
http://firstgenfirebird.org/firebird/1967/ama/24.pdf
1968 AMA Spec's
http://firstgenfirebird.org/firebird...ma_page12.html
1969 AMA Spec's
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
  #49
Old 03-18-2009, 12:58 PM
In case anyones been wondering, my 68 has 115 lb's removed so far.
Probly more then that cause i forget to wiegh some of the small stuff before cleaning up.
And theres more to reamove, but i'm really holding myself back.
  #50
Old 05-18-2009, 05:28 PM
Just weighed my aluminum radiator with dual electric fans
34lbs
keep in mind it had more volume than a 4 row so it will weigh more when filled. No weight savings there from a clutch fan and brass radiator.
  #51
Old 06-23-2009, 08:11 PM
Bare front bumper - 16lbs
The top bumper support - 11lbs
  #52
Old 06-25-2009, 06:19 PM
Both my frt bars wiegh 17. But i'm use'n and old cheap bathroom scale.
Right now the bar sppt(trimmed 4lbs) w/frm brkts is 21.
Still decide'n if i should trim the frame brkts themselves.
  #53
Old 06-27-2009, 01:04 PM
Have not weighed birds but weighed some A-bodies on my forklift scale at work (certified to 2lbs accuracy). The weights below are for original cars, no driver and no gas.
Some are surprising:
69 GTO vert: 4spd AC and heavy optioned (windows, 8 track etc) 3,890
69 LeMans vert: 3502bbl, T400 AC, also fully optioned with windows etc 3,885
69 GTO HT: 4spd AC and again fully optioned 3,855
Porky cars!
Wonder what a stock Bird 400 weighs?
My experience is that a muncie installed is almost 50 pounds lighter than a T400 and a 3spd floorshift (DB13) is about half way between the two (iron case)
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
