SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 02-11-2022, 08:26 AM
ladytata's Avatar
ladytata ladytata is offline
Default Tri power carbs
I have front,back and middle carbs with all brass fittings,2 ported valves and linkage with fuel block. I believe this came off a 63 and can be used up to 1965. $1000 plus shipping text Teri 8473406638
The Following User Says Thank You to ladytata For This Useful Post:
Old 02-11-2022, 11:00 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Can you post the float bowl numbers
Old 02-12-2022, 10:54 AM
ladytata's Avatar
Hopefully you can read it
Old 02-12-2022, 01:33 PM
77 TRASHCAN's Avatar
Oh boy, some interesting stuff you are getting ahold of...........
Shut it off
Shut it off
Old 02-12-2022, 02:28 PM
ladytata's Avatar
Well I guess these are 57 carbs
Old 02-12-2022, 02:34 PM
ladytata's Avatar
You have no idea, I have about $500,000 in car parts to sell, just about ready to hit my first $100,000 in sales in just a few weeks… it’s been crazy
Old 02-12-2022, 03:53 PM
dhcarguy's Avatar
The front and rear carbs could be from 1959 to 1963
The center carb could be 1961 to 1963
64 and 65 , I think the float bowl #'s are on the side of the bowl on drivers side.
Dick Boneske would know for sure.
Dave
The Following User Says Thank You to dhcarguy For This Useful Post:
Old 02-12-2022, 03:56 PM
dhcarguy's Avatar
center carb is a manual trans carb, Not 100% sure though.
I am looking for a correct front or rear carb for a 65
Old 02-12-2022, 04:37 PM
tom s tom s is offline
They for sure are NOT 57 carbs!Tom
Old 02-12-2022, 05:05 PM
ladytata's Avatar
I have more, I’ll try looking next week when I’m at the building
Old 02-12-2022, 05:10 PM
ladytata's Avatar
I printed this cheat sheet, that’s why I thought 63
Old 02-15-2022, 08:27 AM
poncho4284spd poncho4284spd is offline
Default info that I found 1959-1963 carbs
Pontiac tri power carbs 1957-66
1957
Manifold 528533
Vacuum motor 1998829 (mounted on rear carburetor)
Vacuum motor bracket 7011427
Vacuum control switch 7011310 (mounted on center carburetor)
Vacuum motor link 7011428
Front to rear carburetor link 7011009
Front carburetor (A/T, S/T) 7011351 (airhorn casting 7011293, bowl casting 7009094, throttle body casting 1869)
Center carburetor (A/T) 7011350 (airhorn casting 7008594, bowl casting 7009094, throttle body casting 1869)
Center carburetor (S/T) 7011500 (airhorn casting 7008594, bowl casting 7009094, throttle body casting 1869)
Rear carburetor (A/T, S/T) 7011352 (airhorn casting 7010962, bowl casting 7009094, throttle body casting 1869)
Fuel lines steel
1958
Manifold 529371
Vacuum motor 1998827 (mounted on front carburetor)
Vacuum motor bracket 7011280
Vacuum motor link 7012720
Front to rear carburetor link 1011009
Front carburetor (A/T, S/T) 7011705 (airhorn casting 7011293, bowl casting 7009094, throttle body casting 2023)
Center carburetor (A/T) 7011706 (airhorn casting 7008594, bowl casting 7009094, throttle body casting 2023)
Center carburetor (S/T) 7011709 (airhorn casting 7008594, bowl casting 7009094, throttle body casting 2023)
Rear carburetor (A/T, S/T) 7011707 (airhorn casting 7010962, bowl casting 7009094, throttle body casting 2023)
Fuel lines steel
There was also a set of 3 OTC (over the counter) carbs sold for racing. These are 7012351 (front), 7012352 (center), and 7012353 (rear). These differed from the production carburetors in that they were set up for mechanical linkage (also OTC), and had richer jetting.
1959
Manifold 532422
Vacuum motor 1998857 (mounted on front carburetor)
Vacuum motor bracket 7013284
Vacuum control switch 7013670 (mounted on center carburetor)
Vacuum motor link 7013285
Front to rear carburetor link 7013278
Front carburetor (A/T, S/T) 7013063 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
Center carburetor (A/T) 7013064 (airhorn casting 7012710, bowl casting 7009094)
Center carburetor (S/T) 7013067 (airhorn casting, bowl casting 7016085)
Rear carburetor (A/T, S/T) 7013065 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
Fuel lines steel
1960
Manifold 536194
Front to rear carburetor link 7015362
Center carburetor (A/T early) 7015066 (airhorn casting 7012710, bowl casting 7009094)
Center carburetor (A/T late) 7015076 (airhorn casting 7012710, bowl casting 7013679, throttle body casting 3530)
Center carburetor (S/T) 7015068 (airhorn casting 7012710, bowl casting 7016085, throttle body casting 3530)
Fuel lines steel
1960 Super Duty
This unit sold OTC with a mechanical linkage kit, a jetting kit, and aluminum fuel lines. It is unknown to the author why Pontiac issued a separate casting for the Super Duty program, as side-by-side inspection of the two manifolds reveals no noticable differences.
Manifold 535552
Front carburetor (S/T) 7013063 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
Rear carburetor (S/T) 7013065 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
Fuel lines aluminum
1961
Manifold 538202
Center carburetor (4-speed A/T) 7019067 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (3-speed A/T) 7019069 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (S/T) 7019064 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
Fuel lines aluminum *
1961 Super Duty
Manifold 541510 (aluminum)
Fuel lines aluminum
1962
Manifold 541690
Center carburetor (4-speed A/T) 7020067 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (3-speed A/T) 7020069 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (S/T) 7020064 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
1963
Manifold 9770275
Front carburetor (A/T, S/T - 389) 7013063 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
Center carburetor (4-speed A/T – 389) 7023077 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (3-speed A/T – 389) 7023073 (airhorn casting 7017917, bowl casting 7011929, throttle body casting 3530)
Center carburetor (S/T – 389) 7023075 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
Rear carburetor (A/T, S/T - 389) 7013065 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
Front carburetor (A/T, S/T – 421) 7023078 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
Center carburetor (A/T – 421) 7023162 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (S/T – 421) 7023161 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
Rear carburetor (A/T, S/T – 421) 7023079 (airhorn casting 7013206, bowl casting 7011997, throttle body casting 15211)
1964
Manifold 9775088
Vacuum motor 1998857 (mounted on rear carburetor)
Vacuum control switch 7028797 (mounted on center carburetor)
Front carburetor (A/T, S/T – 389) 7024178 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Center carburetor (A/T – 389) 7024173 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (S/T – 389) 7024175 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
Rear carburetor (A/T, S/T – 389) 7024179 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Front carburetor (A/T, S/T – 421) 7024078 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Center carburetor (A/T – 421) 7024074 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor) S/T – 421) 7024075 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
Rear carburetor (A/T, S/T – 421) 7024079 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
1965
Manifold 9778818 (this number often appears to be 9778815 due to a casting problem)
Vacuum control switch – large car 7028797 (mounted on center carburetor)
Vacuum control switch – GTO 7029693 (mounted on center carburetor)
Front carburetor (A/T – 389) 7024178 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Front carburetor (S/T – 389) 7025178 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Center carburetor (A/T – 389 large car) 7025173 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (A/T – 389 GTO) 7024177 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (S/T – 389) 7025175 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
Rear carburetor (A/T – 389) 7024179 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Rear carburetor (S/T – 389) 7025179 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Front carburetor (A/T – 421) 7024078 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Front carburetor (S/T – 421) 7025078 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Center carburetor (A/T – 421) 7025074 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (A/T – 421) 7025070 (airhorn casting 7017917, bowl casting 7019929, throttle body casting 3530)
Center carburetor (S/T – 421) 7025075 (airhorn casting 7017917, bowl casting 7019927, throttle body casting 3530)
Rear carburetor (A/T – 421) 7024079 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
Rear carburetor (S/T –421) 7025079 (airhorn casting 7013206, bowl casting 7029683, throttle body casting 15211)
1966
Manifold 9782898 original cast iron (there is a reproduction of aluminum)
Vacuum motor (A/T) 1998857 (mounted on rear carburetor)
Vacuum control switch (A/T) – 7031598 (mounted on center carburetor)
Center carburetor (A/T – 389) 7026074 (airhorn casting 7031587)
Center carburetor (S/T – 389) 7026075 (airhorn casting 7031587, bowl casting 7031575, throttle body casting 31892)
Center carburetor (S/T – 389 A.I.R.) 7036175 (airhorn casting 7031587, bowl casting 7031674)
Center carburetor (A/T – 421) 7026074 (airhorn casting 7031587)
Center carburetor (S/T – 421) 7026075 (airhorn casting 7031587, bowl casting 7031575, throttle body casting 31892)
Fuel Lines - aluminum *
* Fuel lines – most of the 1961 and newer fuel lines were aluminum, however many of those from the Van Nuys and Fremont plants were steel.
Old 02-15-2022, 09:03 PM
ladytata's Avatar
Here’s a few more I haven’t got to yet
Old 02-22-2022, 07:18 AM
ladytata's Avatar
Sold
