Old 09-24-2020, 01:42 PM
gto19's Avatar
gto19 gto19 is offline
Default Skirt to frame bumper
Hi guys
Does anyone know where I can find one of these? It mounts to the front fender skirt to the frame and it’s rubber
You can see where mine is missing .
Again my pic is rotated when I upload and have no ideas why that always happens.
GM part number is 9785007.
Bumper - Skirt to Frame
Old 09-25-2020, 06:31 AM
Jeff Hamlin's Avatar
I've been looking thought my files and still can't find where I sourced them.
I'll keep looking
Old 09-25-2020, 10:10 AM
421/376 421/376 is offline
If my memory is correct I believe I used Ames part # R142 , $3.00 ea . I may have trimmed the thickness a little to make them fit correctly . Don
Old 09-26-2020, 06:37 AM
R142 comes up as Clutch Pedal Bumper.
I will add that it looks very close the Tub Bumper and may be an alternative ?
Old 09-26-2020, 09:28 AM
gto19's Avatar
Thanks guys
Can’t believe no one makes this part . I’ve also been looking on eBay for a original and can’t find one
Old 09-26-2020, 01:25 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
I’m not sure all 66-67 front fender skirts received these rubber bumpers.
My ‘65 fender skirts are screwed to the frame with a large washer.
My ‘66 fender skirts never had the rubber bumpers.
CT.
ID:	550336   Click image for larger version
Old 09-26-2020, 02:49 PM
gto19's Avatar
Interesting
My passenger side has one and my driver side doesn’t . No big deal I guess .
Old 09-26-2020, 02:51 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
My '67 has both sides in place.
ID:	550339   Click image for larger version
Old 09-26-2020, 07:39 PM
Same on my '66 as shown above.
Old 09-27-2020, 12:40 AM
KGTO's Avatar
KGTO KGTO is offline
So is the consensus to use the clutch bumper? I remember seeing them on mine, we are in reassembly of mine (frame off build) and I do remember seeing those on mine.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
