Old 06-27-2019, 03:40 PM
dataway's Avatar
dataway dataway is offline
Default Steel wheel painting
I've finally got my original dated steelies for the 68 GTO, they are glass beaded, and ready to paint. I'll be using a typical alkaloid oil paint with no primer as per factory finish. I was wondering about using a phosphate dip/treatment before painting ... typical "metal prep" etc. type of stuff.
Do these products actually enhance paint adhesion or provide any real world benefits? I don't recall ever using one before.
Old 06-29-2019, 12:52 AM
how about power coating them.
Old 06-29-2019, 04:57 AM
dataway's Avatar
I actually owned a powder coating gun and oven for a few years. I hate the stuff. Once it starts to go it's a nightmare to remove and refinish.
Old 07-26-2019, 03:00 PM
Dick Boneske's Avatar
If you have the surface clean and use a good primer, adhesion should be as good as factory--or better. The problem I've had with steel Rally II wheels is the silver is easily flaked off the primer. Any ideas on how to prevent that?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-27-2019, 05:01 AM
dataway's Avatar
That has been my reason for hesitating to use primer, for whatever reason, the paint seems to chip easier, or scrape off easier when primer is used compared to an oil base paint on the bare steel.
Old 07-27-2019, 12:00 PM
Did the factory use primer. I don't think they did.
BONESTOCK GOATS
Old 07-27-2019, 01:02 PM
MUSLCAH MUSLCAH is offline
2 part epoxy primer....then 2k primer... then activated single stage...
Old 07-27-2019, 01:19 PM
dataway's Avatar
No primer on the factory steel wheels I've stripped ... and they held up pretty well.
Old 07-30-2019, 12:54 PM
Keith Seymore's Avatar
At some point they used e-coat and then sprayed the color on top of that.
Not sure when that started; this pic happens to be from Flint Assembly circa 1978/79.
K
Name:	Rally wheel.JPG
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 07-31-2019, 12:52 AM
dataway's Avatar
I'm guessing they finished plain jane steelies different than any kind of option wheel. Most steelies were totally covered by wheel covers anyway.
Old 07-31-2019, 06:37 AM
Negative. They all went right down this same line (ie, for white wheels he just grabbed the white spray gun).
K
'63 Grand Prix
Old 07-31-2019, 01:10 PM
dataway's Avatar
Whatever they were doing in 68 it did seem to hold up pretty well, certainly lasted longer than the silver finish on my late model steel truck wheels
