Old 07-27-2023, 06:43 PM
jonra3 jonra3 is offline
Default 1970 F body 1ST desgin rear view mirror
[ATTACH]Click image for larger version
Name:	1970 1st Design rear view mirror F body.jpg
Hi I'm looking for the center section for the 1st design rear view mirror. The center section is a 2 piece section held together buy two screws.
If anybody has one they would like sell, you can contact me @ 419-349-1256.
I'm in the Toledo Ohio area
Old 07-28-2023, 04:43 PM
unruhjonny's Avatar
I have never seen one of those on a '70
At least not on a factory original 1970 (known at the time as "1970+") Firebird.
My suspicion is that this was a 1969 late model year part (meaning 1969 model built during the first half of the 1970 model year; eg: Sept 1969 through to December 1969).
1970 Formula 400
Old 07-28-2023, 07:43 PM
That is a 70 mirror piece. But mine wasn't plain metal, I don't think?
Been about 30 years since i have seen it.
I also thought they used that through the whole year? (1970)
The back of the mirror is chrome look.
Old 07-28-2023, 08:04 PM
If a week earlier I was in Illinois where my car is.
Here is my mirror, snipped from a pic of the interior.
Old 07-28-2023, 08:40 PM
This was the one on my 70 that I had restored. If you have a 70-73 parts book there is a 1st design, then a second design. Here are all the part numbers for the first design.
Group 10.187 9825121 cast aluminum ball. Stuck to windshield.
Then, Arm, mirror support 2 piece: 9816721 and 9816722 use with cast aluminum ball.
Group 10.185 911261 mirror assembly.
Group 10.187 70 All F screw 9809937 Qt 2
This first design was used until around the end of May of 70.
The second design shows up in the later 70 parts book. The 1st design mirror and hardware parts were still available from GM to around 1978.
So I have an nos mirror 911261 and cast aluminum ball 9825121.
I need the 2 supports.
The GM part number for the second design, the common one is 911582 in Gr 10.185.
Old 07-28-2023, 08:45 PM
Most 70 F Bodies had their rear view mirrors changed buy the time any us us were buying them. Even in the mid 70s. It was a poor design, It was known to sag. You could only tighten the screws so much then it would not stay up.
So, you go to the dealer and buy the second design, that's why you don't see the 1st design around anymore.
The Following User Says Thank You to jonra3 For This Useful Post:
Old 07-28-2023, 09:17 PM
Yep, mine is a Feb car. It started sagging just before I made it a racecar.
I used some paper to shim the ball and it holds for a while. Then the glue came undone and a real pain to get the mount stuck on window with the whole weight of the mirror.
I can't remember if i have extra or not. Probably won't be until next summer before I'm back there.
Old 07-28-2023, 09:26 PM
Thanks for the response just put me on your list!
Jon
Old 07-31-2023, 04:03 PM
Name:	1st design arm nos.jpg
Just thought I would show what what it is I'm looking for specifically. These are not mine, used ones are just fine.
Thanks for looking
Jon
Old 07-31-2023, 04:45 PM
unruhjonny's Avatar
thanks for the correction in this one - and the additional information guys!
1970 Formula 400
Old 08-05-2023, 09:15 AM
tdavidl's Avatar
tdavidl tdavidl is offline
i remember the rearview mirror sag VERY well, drove me crazy in the late 70s...i tried the shimming technique as well w/paper, cardboard maybe, etc....i think i finally used string attached to the headliner trim then wrapped around the mirror to try & hold it up...looked ugly but at least i could see behind me when i needed to :-)
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 08-26-2023, 08:10 AM
I remembered this bulletin when looking for something else.
One on the left is what mine looks like.
Old 08-26-2023, 09:38 AM
Held for Ransom's Avatar
More info on the 1st design. Maybe someone can save the photos in case it disappears.
https://www.my1970z28.com/COPO/mirror.htm
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 08-26-2023, 05:43 PM
Dave R's Avatar
Dave R Dave R is offline
Photos saved.
Was this mirror only used in early 70 F body?
Old 08-26-2023, 05:57 PM
Yes.
Thread Tools
Display Modes
