Old 12-31-2024, 11:08 AM
grivera's Avatar
grivera grivera is offline
Default Powell Machine, Inc. Working on a 326
I follow Powell Machine on FB as he has an active channel and his posts are pretty interesting. Here are two in a series where he has started machining a 326 block - part 2 shows the decking process.
Part 1: https://youtu.be/0qs5JTcGWSU?si=zQEPpK_D57E1_7px
Part 2: https://youtu.be/QsoJ3sgSa2A?si=ewOI2djdq7gq55vo
Will Rivera
‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.90 gears, work in progress
'69 LeMans Vert, 350, #47 heads, TH400, 10 Bolt 3.90 gears, work in progress
The Following 2 Users Say Thank You to grivera For This Useful Post:
Old 12-31-2024, 12:06 PM
phil400's Avatar
phil400 phil400 is offline
Thanks for posting, he's got some videos, his HFT video was good too.
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs, 3rd and last owner since ‘99, as long as I'm alive.
79 Parisienne stock original 305 2bbl
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
The Following User Says Thank You to phil400 For This Useful Post:
Old 12-31-2024, 12:09 PM
Formulas Formulas is offline
Watched some of the first video and a question came to mind i wonder how much influence heads being installed on a Pontiac block affects the crank saddle issues he was dealing with ... interesting
If your not at the table you're on the menu
The Following User Says Thank You to Formulas For This Useful Post:
Old 12-31-2024, 01:10 PM
mgarblik mgarblik is offline
Watched both videos. Every engine machinist has their own way of doing things to get the desired results. His method of line honing is significantly different from the way I was taught by my mentor and from the Sunnen training center. I have never seen any Pontiac block warped to the extent he was showing. But to be fair, I have never line honed a 326. 350, 400, 421, 428, 455, IA, IA2, IA2A, yes. Never a wavy block like that. The only block I have seen in that ballpark was a 428 FE Ford. Once the block is all warped like he showed. I would probably stop and install a set of cam bearings and test fit the cam. Because if the block and main saddle is all warped and twisted like that, most likely the cam tunnel is as well. And there is no fixing that without extraordinary effort. A 326 would not be worth it at that point. Also, I counted him stroking the line hone 16-20 strokes without measuring. This means he was using very light stone pressure while honing. I was taught to use very heavy stone pressure so the fixed hone will cut the high areas out and straighten the bore. Low stone pressure tends to just follow the existing bores and more or less burnish then rather than cut them. With the typical pressure I use, 1 stroke up and back will remove .0004"-.0005" per stroke. I generally like .003"-.004" to begin honing. He did flip the block to hone from both ends which is proper. If I have one cap that is going rogue while honing and getting big. I was taught to loosen that cap, just take the torque off it and hone the rest to catch up to the big one. That eliminates re-cutting random caps over and over. In the end, as long as all 5 are round, to size and not tapered, how you get there is not a big deal.
As far as the deck, what he measured was slightly out of the ordinary. .010" end to end is excessive. .004 across is typical. Worst I can remember fixing was a small block Chevy made in Mexico. It was .020" higher on one bank than the other and .017" hi/low end to end. Powell Machine has the same surfacer and BHJ fixture we do.
The Following 7 Users Say Thank You to mgarblik For This Useful Post:
Thread Tools
Display Modes
