Old 06-19-2022, 03:52 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Default 4-speed console pics
Does anybody happen to have a driver side pic of the console installed? Specifically the area where the shifter hump/carpet/console meet?
I’m trying to get my shifter hump welded back in and can’t tell if the drop off from the side of the shifter should be shear straight down with the hump/carpet, or if there is somewhat of a perch or shoulder sticking out a bit then roll off towards the footwell. Car was originally stick, then half converted to auto, now returned to stick.
Not ultra critical, but if I have the opportunity now to get it correct(-ish), I might as well take advantage of it. My carpet is the mass-backed version which I initially thought would help me with placement, but it’s kind of having the opposite effect even after sitting in the sun for a few hours.
Thank you.
Old 06-20-2022, 04:46 PM
Entropy11's Avatar
I ended up coming across these in case anybody is ever searching. I still have a little maneuvering of just the carpet (hopefully) to get to this point.
ID:	593069   Click image for larger version
Old 06-20-2022, 06:02 PM
Look good - glad I ordered the repop unit.
