Tri-Power Tech 57-66 Tri-Power Talk
Old 09-04-2013, 06:57 PM
redhook98 redhook98 is offline
Default What year or era Tri-power carbs are these?
Can't find any numbers on the carbs in my tri-power. The secondary carbs are leaking and they all have issues. Want to rebuild them, but don't know what year or era they are to get the kits. Can any of you tri-power experts make heads or tails of this for me? Are there ethanol-proof kits?
Thanks!
ID:	335756   Click image for larger version
ID:	335757   Click image for larger version
ID:	335758   Click image for larger version
ID:	335759   Click image for larger version
1966 Impala SS
Old 09-04-2013, 07:12 PM
Old Man Taylor's Avatar
It looks like a 1966.
Old 09-04-2013, 07:42 PM
Keith Seymore's Avatar
Originally Posted by redhook98 View Post
Doh!
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 09-04-2013, 07:51 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
1966 nothing better looking than Three Deuces...
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 09-04-2013, 07:55 PM
Great, thanks! Is that a good year/era for these? Anything look glaringly wrong in the pics (except for the gas pouring out of the gaskets)?
1966 Impala SS
Old 09-04-2013, 09:01 PM
Kenth's Avatar
Kenth Kenth is offline
YouŽll need to locate the ignition coil at rear of passenger side cylinder head.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-04-2013, 10:46 PM
Coupe62's Avatar
Coupe62 Coupe62 is offline
The routeing of the fuel lines looks a little odd. Of corse I am used to looking at 62, 63, and 65 units, but the fuel lines don't look right to me. Just my opinin. Sorry, I recant that statement, just looked at a picture of 66 unit and your lines look correct
1962 Catalina 421 Tripower 4-speed "Red"
1962 Grand Prix 389 Tripower 4-speed "White"
1962 Corvette 402hp 350 4-speed
2009 GMC Yukon Denali
2011 GMC Yukon Denali
Old 09-06-2013, 01:44 PM
Doug Doug is offline
Thumbs up Appearances??????????????
The '66 setup uses a larger center carb than earlier ones and, accordingly, is a "better" setup. It fits 65 and up heads. There is a school of thought/opinion that the 1965 "small center carb" setup is not sufficient for optimal performance of larger displacement engines.
The setup pictured appears to be pretty good functional setup.
One thing that appears "incorrect" for this '66 setup is that the "progressive link" connecting the middle carb to the rear carb is a "plunger type" as opposed to the typical "slotted bar" setup. The "plunger type" was used on earlier 60's cars and a changeover was made to slotted bars maybe in 1964. This plunger type is available in aftermarket versions. The original plunger type had some safety concern issues with the possibility of the plunger rod coming out of the socket and binding up the end carbs in a wide open position.
Although the plunger type was not used in '65, some sales brochures had pictures/drawings of engines with plunger setups.
Old 09-06-2013, 03:00 PM
To address your ethanol concern: a couple of the carb builders (Mike's Tripower, for one, and Cliff Ruggles - who recently retired) have accelerator pump plungers made out of leather rather than rubber/plastic. This are supposed to fare better with alcohol than the previous versions.
K
'63 Grand Prix
Old 09-06-2013, 03:53 PM
zeebo's Avatar
zeebo zeebo is offline
K
cliff ruggles recently retired???!?!?
Old 09-06-2013, 04:07 PM
I picked up the Echlin kits. Will see how those go. After that I will explore the leather pumps.
As for the linkage, it did pop out on my once already. Not sure how. I can slam it around all day long by hand and it is solid. ? Will update it after I get it running 100%. Can I get just that slotted bar to update it?
Also, is there supposed to be a kick-down linkage connection somewhere? i have an older (late 60's) TH400 installed. No kick down at all right now. Shifts firm and smooth, but no kick down. this is what happens when the guy you get a car from has no idea what had been previously done to it, and is not a car guy.
I am not even sure what motor is in it! The code on the from is YU (or YO) and 0687610. Was told it was a 1968 400 or 428. ?
1966 Impala SS
Old 09-06-2013, 04:39 PM
67_Krewzer's Avatar
67_Krewzer 67_Krewzer is offline
Definitely check out Mike’s site http://www.pontiactripower.com for tri-power parts and info.
67 Firebird auto
65 GTO Hardtop 3x2 WS M22
Old 09-06-2013, 04:58 PM
Default KIckdown stud...
When i use a turbo 400 with Tri Power i use the 65 tri power linkage on the center carb. The 65 has a longer arm than the 66 for the center carb. You can buy a kickdown stud from any of vendors and attach it to the lower end of the center carb arm. The 65 and 66 linkage kits are the same except for the center carb arm, they will interchange.
Old 09-06-2013, 07:24 PM
It's a YU.
Could be a lot of different years and displacements.
Engine codes
Have to see what the date code casting is on the engine.
Old 09-06-2013, 08:12 PM
To add to my above post you will need to fab a small bkt at the rear of the manifold to hold the cable. Also i think Lokar makes a kickdown that mounts down on the trans but i have never used one yet...
Old 09-06-2013, 09:23 PM
Might be "Cliff R".
One of those two.
They might be the same person. Ever notice you never see them both in the same thread at the same time?
'63 Grand Prix
Old 09-06-2013, 10:02 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Might be "Cliff R".
One of those two.
Sure you aren't talking about Jon of the Carburetor Shop?
Cliff was just giving advice and someone posted about calling him to buy parts just the other day.
Old 09-07-2013, 07:36 AM
chrisp chrisp is offline
What color are the accelerator pumps ? If black they are no good for ethanol fuel , you want the Blue ones made out of Fluorelastomer that are alcohol resistant . I have them if needed . As for leather , not a fan .
Old 09-07-2013, 10:18 AM
I believe that is correct; that's who I was thinking of.
Thank you -
K
'63 Grand Prix
Old 09-07-2013, 11:47 AM
I will get back to you on this. The kits will be here on Monday. If they are black, I will pick up a few of the ones you recommend. I will PM you if I need em. thanks!
1966 Impala SS
