#61
z QdobaThank You
#62
A bit late but Welcome to the forums. That is one nice setup.
#63
Finished up the cut and polish yesterday and now working on the dash and garnish moldings.
#65
Welcome from the Evergreen State.
Great project and work.
JLP |
#66
Thank you Jack.
#67
Got all the garnish & missalaneus moldings, brackets and heater lasted Friday, everything in epoxy Saturday then wet sanded with 600 and painted in acrilic laquer today.
#68
couple more
#69
Damn you are quick, nice work! Can't wait to see it finished.
#70
Thanks, I can't wait to see it finished as well.
#71
I am a little late to the party, but belated welcome and kudos on the fine work.
#72
Took the steering column apart yesterday blasted and painted then reassembled today.
#74
Got the Fat Mat done today.
#75
Been working on some small stuff the last few days like all the rubber plugs that go in the floorboards and trunk pan. I blasted them then washed with soap and water and installed. Very time consuming but these are all original to the vehicle and in excelent condition. Then went down to the local upholstery shop and picked up some tack strip for the headliner and some new insulation for the firewall pad. My cardboard was in real nice shape but the 1" fiberglass insulation was falling apart. The dash cover also used the same 1" fiberglass insulation so I got enough to do that as well. Cleaned up the firewall cardboard, made up the new insulation pad and glued it on with contact cement. Went to lunch, came back from lunch and installed the firewall pad...:brow Then today I installed the tack strip and then the headliner, no wrinkles used my heat gun. I also picked up a upholstery stapler and a new pair of scissors from these guys.
http://www.upholster.com/toolkits/staplers.html |
#76
One more pic of the headliner trimmed and dome light installed. Will be working on the heater and dash today.
#77
Finished up the heater today. Will start on the dash assembly tomorrow.
#78
It's interesting to see how far back the dome light is on the '60 models.
#79
Its not that dome light is back so far as the roof is so short. The light is actually just about even with the back of the front seat.
#80
So it's probably the huge back glass that gives the impression, no?
Greg Reid Palmetto, Georgia |
