Old 09-20-2018, 05:02 PM
tekuhn tekuhn is offline
Default '70 Judge Hood Scoop Insert Warpage?
I'm restoring a '70 Judge and currently working on the fiberglass Ram Air hood scoop inserts. I've noticed that the inside upper leading edge seems to be tilted upward compared to the left insert. Is this normal or has mine warped? I've attached a picture to show what I'm talking about. I feel certain these are the original inserts to the hood which still has original paint and Ram Air decals. Thanks for any help!
Tom
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures
Old 09-20-2018, 06:23 PM
Forrest's Avatar
Forrest Forrest is offline
How does it fit in the hood.. can you show a picture of that?? It would help others to identify the problem if any..I have had to "modify" them with fiberglass to get them to fit near perfect..they tend to change over the years..yours look like they could use some care..
Old 09-20-2018, 06:41 PM
The outside edge fits the contours of the hood just fine. I'm not sure how the leading edge could warp upward and still the outside edge meet the sheetmetal correctly, but it does. That's why I'm suspicious it was made this way. I'll try to take more pictures that illustrate my complaint better.
ID:	493216   Click image for larger version
Old 09-20-2018, 11:20 PM
I took a heat gun to it and possibly moved it back slightly and then spent a few hours sanding and filling. I think it looks pretty good. It has a couple coats of primer drying tonight and then I can fine sand it and see how it looks tomorrow. It's not perfect, but better than a repop. The left insert had a major crack in it and one of the mounting stud ears was broken. I'm working it with epoxy resin and fiberglass cloth. It looks like it will turn out good as well.
Old 09-23-2018, 01:42 PM
I'm not in front of my cars now but I know that factory 69-70 Ram Air scoops all had one side (i think passenger) that had a crooked look like that on top, just a poor factory mold I guess. When I repaint a Ram air scoops I always cheat a bit and have them "blueprinted"
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 09-23-2018, 11:59 PM
Thanks North - I have no other cars to look at, but I really suspect that this part was molded this way. I'm basically sanding and filling as much as possible to improve the fit and appearance and then I'm going to call it done and good enough.
Old 09-24-2018, 10:29 PM
3goats's Avatar
3goats 3goats is offline
That is the way they came from the factory. At least all the ones I've seen
Old 09-25-2018, 09:19 AM
Thanks for the confirmation.
