Old 01-09-2021, 06:52 PM
allenga allenga is offline
Default Bearing Race Question
Hello Gentlemen,
Doing a brake job and am replacing bearings and rotors too. The new Timken bearings come with new races. The new Raybestos rotors also have new races.
Do you think I should pound out the races in the new rotors and put the Timken races in so it matches the Timken bearing.
Thank you
Attached. Gratuitous bling photo.
Old 01-09-2021, 07:02 PM
PontiacJim1959 PontiacJim1959 is offline
Yes, I would. With the way world supplying is today, you could have a race that was made anywhere in the world, but have the same brand name, and be just a hair off in spec and find yourself pulling things apart. With the matched set, you won't need to second guess yourself if you should hear "that noise" coming from the rotor.
The Following User Says Thank You to PontiacJim1959 For This Useful Post:
Old 01-09-2021, 07:22 PM
STEELCITYFIREBIRD's Avatar
I would use the Timken races.
I also would recommend replacing the brake hose/s you clamped with vice grips!
The Following User Says Thank You to STEELCITYFIREBIRD For This Useful Post:
Old 01-09-2021, 08:07 PM
Yes, new hoses in the box.
I was not looking forward to changing races. Not sure why all the new rotors have races installed when they don't sell matching bearings.
Old 01-09-2021, 08:15 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
New rotors obviously have to be accurately machined, also. Hence races in new rotors.
There’s minute things about bearings and races that you can’t see. Always use matching bearings and races!
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 01-09-2021, 11:08 PM
If your not comfortable changing them, your better off using the ones already installed, considering the miles your likely to put on the vehicle.
Old 01-09-2021, 11:09 PM
I'm going to do it. Will go rent the tool on Sunday
Old 01-10-2021, 12:47 PM
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
For the cost a nice tool to own!
Old 01-10-2021, 01:03 PM
mgarblik mgarblik is offline
X2. If your more comfortable changing them and have the tools to remove and replace, then you should do it. Just to be factual, bearing cups, (races) and cones, (the roller part) are not a matched part. They are not lapped together, ground or machined in any way that makes them a {matched set}. That is an old wives tale. There could be a quality difference between the cup in the new rotor and a Timkin cup but who knows. Most of the Timkin bearings are made in China now anyway. A few are still made in the US. Country of origin should be on the box. Now you may have heard you should not mix bearing cups and cones from one side to the other and so forth. That is true, if they are USED. Once put into service, they do lap together and form a unique wear pattern. Either way, you should be fine. I have had several instances of cups turning or spinning in the hubs from being removed and replaced many times. I have never had a wheel bearing failure from a "mismatched" cup and cone in 40+ years of doing this type work.
Old 01-10-2021, 02:20 PM
Thank you. Are you saying if I slap my new Timken bearing in the new Raybestos rotor that has a new race, they will be fine?
Old 01-10-2021, 02:50 PM
My opinion yes.
Yet Another Excellent explanation, as usual, Mgarblic!
Shame Timken is sourcing offshore, I have been out of the automotive parts/repair business a long time, use to be a very high quality manufacturer of bearings.
I paid the premium price for wheel ends for my Taurus last year ....thinking I was buying USA made, top grade part.
Old 01-10-2021, 06:22 PM
geeteeohguy's Avatar
I think you'd be ok either way. Provided you have the skill to drive the new races in without damage (race driver or brass punch). NEVER use vice grips to clamp a rubber brake line. Instead, slip an old valve stem or vacuum hose into the banjo fitting to stop the drip. You are probably looking at new hoses at this point.....as the vice grips damage them internally.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 01-10-2021, 09:57 PM
To keep the brake fluid from draining the reservoir, just push the brake pedal down slightly enough that the ports are covered in the MC. Be sure the brake lights are not on! or disconnect the battery. Brake fluid washes off clean with water, if you didnt know. Save that Brake Cleaner for oily stuff!
Bill Nye.
The Following User Says Thank You to TedRamAirII For This Useful Post:
Old 01-10-2021, 10:10 PM
I meant to clamp off the brake hoses and ruin them.
