1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 04-06-2004, 11:10 AM
onebadbonne onebadbonne is offline
Does anyone know of anyone who makes drop spindles or lowering springs for 78-79 B-Bodys?
Also will the suspension componets from later b-bodys(94-96 impala) fit the earlier b-bodys? Last does anyone know where old 9c1(pre 1990) caprices can be found (again for suspension) ?
Old 04-06-2004, 03:31 PM
75cancup 75cancup is offline
Have you tried www.car-part.com , it should help you in your area. mike.
Ban low performance drivers... Not high performance cars.
Old 04-07-2004, 05:30 AM
Mister421 Mister421 is offline
Hotchkis makes the springs you are looking for listed as the 94-96 B-Body springs. There is also a spring mfr. (I can't think of the name right now - Detroit something) that can make springs to custom applications. Not sure who has the spindles. The later model spindles will fit the earlier models. We did an 81 Bonneville 2-door with the late model spindles and added 1LE brakes to it. We also used the Hotchkis springs. Not sure where you can find pre 90 Caprices. Hope this helps.
