1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 01-14-2004, 10:11 PM
WARPed's Avatar
WARPed WARPed is offline
We are now in the beginning stages of our 85 GP project and have a question. I would rather not put any kind of scoop on the hood so my question is how much clearance have you guys had with various intakes. I have an assortment of intakes for the 400ci/E head motor, just trying to find out before we go to put the motor in.
with out questions there can be no answers
1969 Grand Prix
9.947@133.53(1.358)
6.246@107.91(1.342)
WARPed Tepee Forums
alex@pontiacgroup.com
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
WARPed's Avatar
1969 Grand Prix
9.947@133.53(1.358)
6.246@107.91(1.342)
WARPed Tepee Forums
1994 Formula
Old 01-15-2004, 06:37 PM
BradZZ BradZZ is offline
I have an 81 GP w/ a 400, 6x heads and
edlebrock Performer intake with a Q-jet on it.
I have no clearance problems with either
a factory breather or the typical
14" aftermarket chrome lid w/ open air filter
Old 01-15-2004, 08:00 PM
WARPed's Avatar
Thanks; the 81 GP uses the same hood all the way up to 87. What motor mounts (on the block) did you use, 78-80 GP 301s or? Also how tall of an element are you using and is it a drop base bottom? I want to be able to use the RPM intake and at least a 4” element with a drop base. Thanks for your reply.
1969 Grand Prix
9.947@133.53(1.358)
6.246@107.91(1.342)
WARPed Tepee Forums
1994 Formula
Old 01-16-2004, 08:06 AM
the ones i have done i used 74-7 frame mounts. they shoud be the same as the sbc units.
the height can be changed with the engine stand as there were 3 different stands made to my knowlege that fit this stlye of mount.
if you have 301 units they will probably work.
mike
former." --Albert Einstein
- Winston Churchill
