Pontiac - Street No question too basic here! |
View Poll Results: When should a torque plate be used when boring a Pontiac engine? | |||
EVERY single build no matter what. | 31 | 88.57% | |
400 HP | 1 | 2.86% | |
500 HP | 1 | 2.86% | |
600 HP or more | 2 | 5.71% | |
Voters: 35. You may not vote on this poll |
Having run a boring bar I would say yes, however my shop teacher used to have me just bore stock engines without the torque plate and reserve it for performance builds. But since most people on here are building at least a mild performance engines I say it should be used.
Rocket Racing & Performance LLC makes aluminum plates for 365$ CCA Racing Products makes one too.
Once the honing is done, per the technique above, the bores would be round and taper-free within +/- .0001" Well, that is until you unbolted the torque plate, then they'd go out of round as the block relaxed. Bolt the heads on and measure from the bottom and back to round though they were never perfect. Still, way better than without the torque plate. Near as I can figure, a torque plate is not a head and the stresses on the block end up being slightly different between the two. A good plateau-hone, the proper cross hatch pattern, and some moly faced rings and an engine will seal up almost instantly.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
I can't swear if Sunnen actually makes the plates themselves or buys them from someone else and paints their name on them. When we bought a bunch of equipment for my college from Sunnen, we were able to get some "accessories" for the new equipment as part of the package deal. I was able to pick 6 torque plates and of course a Pontiac V-8 was one of the 6. Since that purchase, I bored the plate for large bore IA II blocks. 4.425". So now it's too big for typical 400-455 stick blocks. That's when I bought a BHJ plate for the smaller bore Pontiacs. After using both, the BHJ one is just a little nicer because it has counterbores for the fasteners that work nicer with spacers when running studs. Either will get the job done. We made our own plate for a student with a Jeep 4.0 L inline 6 and another one for a student racing a Studebaker 289 RIII. It's allot of work to make one IMO.
Engines with 7/16 head bolts and small bores distort the least. Dan told me he had his own personal tq plates for every American V8. Even AMC. They guy was anal about bores. When I told my local guy about how much they distort he is the one who decided to bore it .010 under so he had a solid .002 to hone out. |
My 2 cents. I think a torque plate is overkill for a street engine.
OK, so you use the plate, but think of all the variables that can get that precise perfectly round cylinder out of round. Heat & expansion. Heaven forbid some of your cylinders don't run even temps and one runs hotter/colder and it expands differently. Are all cylinders the same temperature from top to bottom, left bank to right bank, front of the block and back of the block? What if the intake is not perfectly matched to the heads and one head is .010" less on the intake side than the other and you torque it down and the bolts draw the head in, pulling on the head bolts, pulling on that one bank of cylinders. OMG, distortion. How much block distortion do you get when the engine torques over against the motor mounts? Or the twist applied to the back of the engine via the rubber trans mount as the driveshaft loads up the posi unit and sends it to the wide tires that dig in and twist the frame. For a drag race only engine, I can see the benefits where every ounce of HP can make the difference between win & lose. Blueprinted assembly, hard block fill to stiffen the casting, front/rear engine plates, roll bars to stiffen/eliminate frame twist, etc.. But for a street engine, I can't see it and have never used one. That's why engines have tolerances. |
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
The Following User Says Thank You to hurryinhoosier62 For This Useful Post: | ||
As hard as it may be to believe, torque plate honing is worth 8%-10% in peak HP on an engine dyno. It has been proven time and time again. On a 400 HP street engine, that's 32-40 HP. That's not just on a Pontiac, but typical for American V-8 engines. If the goal of the rebuild is to cruise around on a Sunday afternoon from one car show to another, or drive the car in a parade, I agree torque plate honing is not necessary. I have run a ball hone through many, many engines and put the old pistons right back in and away they went. But there is real HP just sitting out there waiting to be had and it's a fairly inexpensive up-grade to an engine rebuild. My rule of thumb is, if the engine is getting new pistons, it's getting torque plate honed. This includes even 5 HP Briggs and Stratton engines for say a Jr. Dragster. It makes a huge difference in those little engines. Joe Mondello was under contract with Briggs and Stratton to develop machining practices for their Jr. Dragster engine. Torque plate was worth 2 HP on a 20 HP Jr. Dragster engine. Same 10%. Verified on the little dyno.
I would like to add that PontiacJim 1959 made some good points about the many variables of heat cycles, uneven heating of different cylinders, and external forces on the block from mounts, and even the intake. Huge money has been spent trying to duplicate those forces while honing. I have honed blocks with the mounts on the block, the bellhousing attached and used a hot hone that circulated 180 degree honing oil through the block while honing. Believe it or not, going through all that aggravation on different blocks, Chevy, Mopar and Pontiac, it didn't show much on the dyno. Possibly a few HP, but not enough to really verify. So we discontinued the process. Some cup teams and Pro Stock still hone that way. Last edited by mgarblik; 04-14-2020 at 09:04 PM. |
Chris at BHJ states that their plates should be used for final hone and cast iron plates are used for cast iron heads and aluminium plates are used for aluminium heads. And spacers not stacks of washers should be used to hold the plate down. He emphisized this because there are two different lengths of spacers used for pontiac heads ; one for cast iron heads and another for ram air. Aluminum heads like edelbrock that use longer hardware. Interesting. Says BHJ does not supply bolts or studs with their plate . Interesting that sunnen does. There's a thread about this same subject on yellowbullet right now too
I disagree with not torque plate honing on a street engine. Maybe I'm pickier than most but I prefer the cylinders to be as round as can be in operation for proper ring seal and less blow by for a nice tight running engine, regardless of the HP goal. As much as it costs to build these engines today and the amount of time and effort involved, I just don't see why someone wouldn't want that.
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Pontiacs need it more than most engines, not less. Myself, I am wondering how much of a difference there will be since my engine was honed with a iron plate but will use aluminum heads. At least for awhile.
I would like to put the HOs and Warrior Dan did for me back on after I play with the High Ports. If I can get to 10.83 with 9.3-1 and a junk 455 with a cam I bought of E Bay on a whim, maybe I can get to 10.60 or even 50s with a engine with better stuff, all fresh and custom Crower cam he designed for the heads on pump gas. 10.50s in a heavy car at 9.3-1 on 91 piss gas would be a accomplishment for me. I know its best to use aluminum plate with aluminum heads, what is the actual difference in power if iron plate is used ? |
Call BHJ and ask for Chris. Iron ones go for 550 dollars an come with spacers for factory iron heads. The other spacer hardware kits cost another 60. The aluminium plate goes for 750 but that's because they are heat treated. If your machinist does not know when or how to use one Chris said you should bore the block to within .007 without the plate then hone the last .007 using the plate. They make the plates so it's a good bet. They know how to use them.
