Old 08-13-2019, 11:05 AM
KGTO's Avatar
KGTO KGTO is offline
Default Front brake lines and brackets
My car is original power drum and I will be converting to either Wilwood or Baer brakes. I am replacing the brake lines so first question is,
-since I have headers on the car, I thought it might make better sense to use the pre-bent lines for a R/A HO car since it may provide more clearance. Can anyone confirm?
-The frame brackets that bolts to the frame and the flex lines hook to are different from drum to disc. The disc brackets look longer. Any reason I can't use the frame brackets I have?
I had converted my drag car to discs ( 65 GTO, sold) and I don't remember having any issues with the brake hose length. Additionally, I had my brackets powdercoated when the frame was done, separately of course. ...and obviously if I retain the drum brake brackets I will want to use the pre-bent kit for power drum brakes. Yes I realize I will have to adjust at the m/c for the proportioning valve.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
