Old 12-20-2020, 06:19 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Default 68 Firebird rack alternatives
I had been considering a rack and pinion, but after seeing all the issues people have with Pontiac engines and systems designed for Camaros, I looked at alternatives
The combo I'm leaning toward now is the truturn and a quick ratio (10:1) manual box
Anybody running something similar?
I'm just not sure about the 10:1 on a street car that I will probably only see occasional autox and track (not drag) time with
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 12-23-2020, 07:02 PM
JLMounce JLMounce is offline
I have a lares box in my 69 bird. It’s advertised as a 10:1 ratio, but I don’t think it’s actually that quick. Probably closer to 12:1.
That said, it’s well mannered on the street. It’s not twitchy which was one of my original concerns.
In a stock subframe, the rack causes more issues than anything. Anything you gain in road feel is overshadowed by fitment issues, worse than factory bump steer and reliability. Aftermarket subframes designed around a rack are far better.
On the TruTurn system, I to date haven’t been able to get a straight answer on if it fits with a traditional poncho. It piggy backs off the factory drag link and you may run into oil pan clearance issues. Since I could never get a straight answer I decided I didn’t want to be the guinea pig.
-Jason
1969 Pontiac Firebird
