1972 400 block .060 $300 with N crank
1972 400 block rough bored for .060 over. It had some pitting in one hole I wanted to be sure it was ok for .060 over and it is. Comes with the original N crank for this block and it’s standard. $300.00 pick up only.
That's close to all you can go. You would need to sonic check the block to see if you can go bigger or you would need to sleeve the block.
That’s all it needs to go finish hone line hone and assemble. Going .060 over is not a big deal.
Norwalk
Bump
Norwalk
Bump
I have a complete set of.065 forged pistons, pins, rings also for this build if anyone is interested before I start on it myself. Pistons are 21cc Dish $850 for block crank and piston kit.
Bump
Bump
Bump
