Old 03-25-2003, 10:50 PM
Bigred455 Bigred455 is offline
Can someone tell me what the dimensions of torque converter bolts are? I went to put my old ones in, and noticed their thread size was a tad small, as they had "rattled" around, and banged the threads on the flexplate.... I would like to avoid from this happening in the future, lol. thanks, George
George Hill
'63 Star Chief, '95 Chevy P/U, lots of BMW motorcycles and cars
George Hill
Old 03-26-2003, 04:58 AM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
Use thread locker, Loctite, or lock nuts. Allen Wrench makes a locking bolt with teflon patch, or teflon ball inserted in the threads. I tear down twice a year, and I use nyloc nuts, a nut with nylon locking ring. With any of these thread locking materials, alway use new each time. For the street use a thread locking liquid, or a crimped locking nut, these are nuts put under pressure to distort them slightly, there are many on market. Don't know exact size, but I think your problems happened after they come loose. The bolts gets worn when this happens it will make the holes in flexplate larger, making proper bolt fitting impossible,
BIGGERISBETTER-15 yrs in NHRA tech ret.
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 03-26-2003, 07:05 AM
tikiklubracing, The style I have is where the bolt actually threads into the torque converter itself, not to a nut on the backside.
George Hill
Old 03-26-2003, 10:46 AM
If it's a factory converter,I think it's a 7/16" fine thread bolt.
If it's aftermarket,hard to say.A lot of them are different.
johnta1
Old 03-26-2003, 02:46 PM
myckee's Avatar
myckee myckee is offline
Make sure you measure the threads. Just like the factory used on my '80 Firebird, my aftermarket converter used METRIC bolts.
Old 03-26-2003, 07:44 PM
stevep's Avatar
stevep stevep is offline
Depending on the trans,most GM converter bolts are 3/8" course.
If your original bolts were metric,it will have a number with a decimal point in it, IE: 8.8 .
If your converter is metric,the American bolts will thread right in.Make sure you go in a few turns and see if the bolt wobbles.If it does,go to a metric bolt.
I think the metric size is 10mmx1.50(not sure)>
The difference between in-laws and outlaws-outlaws are wanted
Old 03-26-2003, 07:52 PM
I bought some 7/16" Fine thread bolts and they wouldnt begin to thread in.... meanwhile I went to AutoZone to get some Liquid Teflon, and in their help section they have converter bolts so I bought them. The screwed in nicely.... 10mm x 1.5 did it. Thanks for the help, George
George Hill
Old 03-28-2003, 01:39 PM
Tim Corcoran's Avatar
Liquid Teflon is a lubricant not a locking device. You don't want to use a lubricant you want to use a thread locking device like Locktite. Make sure you use the blue locktite as the red makes it extremely difficult to remove. Those three bolts are transferring a lot of torque this is a critical fastener application. Make sure you use grade 8 bolts.
Tim C
65 LeMans, 3600lb. all steel, full interior, D-ports and a flat tappet cam, 11.01@120
Tim Corcoran
