Battery drain
Hi guys in my 70 gto the batt goes dead in hrs load tested batt. Ok removed all fuses still shows drain using test light in series with batt also disc alt and voltage reg still shows draw I'm at a loss any ideas? Thanks
Did you disconnect the neg cable from the post and then put the test light on the post and the other end on the cable? Just trying to clarify before proceeding.
That's exactly how I did it
Next I would recommend using a amp meter the same way to get and idea on the amp draw. This should help narrow it down some.
What I have is a clamp meter what else could cause a drain without any fuses or alt and volt reg disc? Starter?
Somewhere there is a circuit that is staying closed even with the ignition off. If you can get a read on the amperage draw maybe you can eliminate certain circuits. Since it goes dead in hrs., sounds like a huge draw. Possibly at the starter.
Do you have any add on electrical components? Radio-alarm-etc? Is there anything that isn't working? Horn- dome? Is there a big spark when you reconnect the battery cable? If there is not a big spark at the battery when reconnecting, I suspect a battery even though you had it load tested and maybe a small amp draw. I highly doubt it is the starter. I suspect something in the lighting circuit. Dome-glovebox-trunklite. With the battery disconnected and a test lite connected inbetween and the lite is on, try touching a jumper wire from the battery to the cable (Test lite still connected). You may see or hear something while repeatedly touching the jumper wire. If the lite goes out and stays out after touching the jumper and then disconnecting it you have something loading up like a clock or a condenser and it is not a true short, but normal.
Not much left to draw but the starter solenoid. Are there any aftermarket devices on the car? Need to connect a digital amp meter and see how many amps it is drawing.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
If it's just a small amount I would look at the glove box light staying on or the trunk light staying on to. You can't see them when the door or the trunk lid is down but that has always been a spot that would give problems on all kinds of cars even today.
Does the battery cable get hot? , If so, your positive cable could be touching the block at the starter and the paint may be acting like a weak insulator. I know sometimes it difficult to get that group of wires sitting problem free. Killing a good battery in a couple hours is possibly a fire waiting to happen.
John |
Just chased this problem down on my 70 GTO. Turned out I had tapped into the unused glove box light positive wire for my stereo constant wire. I just undid that connection. I have yet to decide on a resolution as now my stereo keeps no memory because of this. Factory stereo did not need a constant 12v supply because there was no clock in it.
This might not help you any but, sometimes it's nice to know your not the only one out there chasing electrical issues. Good luck. |
Well, it did. Thats the only thing I disconnected and I no longer have that draw. But, I too did not believe it was possible. I might hook it back up and see though since I bought a new battery last night.
My guess it had more to do with the battery than the draw. |
It started out the battery was dead after about 2 weeks. Then got to where it was a few days then to 24 hours. That would be a crap battery (2 times which is possible) |
Well hooked up amp meter found 6 amps with no fuses installed disc alt drain went to .5 amp hooked alt back up and disc volt reg found same result so the prob is either reg or alt the test light was too vague the amp clamp ( fluke 377) def did the job so I have a new alt on the way Friday will hook it up and post result on here thanks guys
If the diaod trio is bad/shorted it will eat ab battery up in short time. I think with the atl. change you will have it fixed.
Turns out it was the advanced auto alternator replaced with an ac delco unit now amp draw shows .6 amps batt has been at 12.7 all day thanks guys!
