Old 12-03-2021, 05:00 PM
lugnutx2 lugnutx2 is offline
Default pulling engine with long branch manifolds
I'm about to get our 68 firebird out of storage, so I can pull and reseal the engine, the engine has never been out of the car and it still has it's original long branch exhaust manifolds . I don't have the car in front of me, so I'd like to know if it's possible to pull the engine with the manifolds still bolted on?
Old 12-03-2021, 05:07 PM
There was a thread on this a few weeks ago (or was it pulling a starter?).
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 12-03-2021, 05:12 PM
grandam1979 grandam1979 is online now
We don’t do it like that we take them off and install after engine is in car they will come right in from the bottom. With yours never being off the bolts might be a issue. If possible I would remove starter also. On a car like mine that’s been apart before the manifolds will take a half hour to do very easy. Also once your putting it together drop in engine then install starter wire it then the manifold works great.
The Following User Says Thank You to grandam1979 For This Useful Post:
Old 12-05-2021, 06:54 PM
tanksteve tanksteve is offline
I just looked at mine. Driver's side long branch will probably hit the steering box, so could remove that
Old 12-05-2021, 09:34 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Should be able to remove the starter and have room to slide them out. Never had to pull the steering box..
Old 12-05-2021, 10:35 PM
That was me on the starter, I installed a new wiring harness and the car started right up.
Old 12-05-2021, 10:43 PM
Since they've never been off before, the manifold bolts are the issue, I can see them breaking off if I try to remove them in the car. I need to pull the engine for a reseal and paint and would like to have plenty of room to work on the manifold bolts. I'm going to try and do this in the next few months, I'll post the results. Thanks!
Old 01-17-2022, 08:42 PM
jdaniels1000 jdaniels1000 is offline
it is possible, just did it on my 69 but very tight around steering box and some trouble getting starter past the engine frame mount. pulled mine for a reseal and paint, will probably put the manifolds on after engine is in car and a new mini starter
Old 01-18-2022, 12:36 PM
Sport69 Sport69 is offline
Spray your manifold bolts with Deep Creep, or PB Blaster days before you want to attempt to remove them. Let it set for a day, and spray them again, repeat the process a few days in a row to let the penetrant work at breaking the rust loose. I've also read that you can heat them with a small propane torch and then take a crayon and touch it to the bolt closest to the engine, supposedly it will melt a little of the crayon and literally suck it into the threads of the bolt. I've never done that, but I have heard it works.
When you do start to loosen the bolts, only back them out a little at a time, then tighten them back down half the distance you loosened them. You want to repeat that process over and over, retightening them about half the distance that you've loosened them each time, slow and easy! You can also spray more penetrant on them if you feel it will help. Check out YouTube for some videos on this process, hopefully you can get them out without breaking them. Be sure to use a 6-point socket too, it's less likely to slip or round off the bolt head.
Here's one video I feel is a good one.
https://www.youtube.com/watch?v=9PKNCVXvZ6w
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
The Following User Says Thank You to Sport69 For This Useful Post:
Old 01-25-2022, 08:26 PM
Thanks guys for the tips, I plan on tackling this in the Spring, if I still have the car.
Old 01-26-2022, 12:38 AM
400 HO Firebird or RA ?
Old 01-26-2022, 11:04 AM
It's a 68 400 HO, 4 speed with added ram air system. The guy I bought it from said the original owner was a GM tech and he THOUGHT the ram air stuff was over the counter, at any rate, it's been on the car a long time. I think the RA is after-market, but I have no way of knowing.
Old 01-30-2022, 11:09 AM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
you can pull engine with manifolds on
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
The Following User Says Thank You to Richie Hoffman For This Useful Post:
