Lithium-ION battery
Anyone running a lithium-ion battery on a mostly street driven car? I know they need a special charger, but wondering if they work with a conventional electrical system and alternator, or whether something special is needed? Although expensive, the size and weight opens up a lot of options for placement in my pro-touring project.
I still don't trust them. They have a documented history of fires. Until they get to the bottom of that I'll stick with an Interstate lead/acid battery.
The Following User Says Thank You to Chief of the 60's For This Useful Post: | ||
I've been in the market for a new Travel Trailer and have noticed Lithium batteries are now an option on the Lance. I believe the option comes with solar panels and a special charger but...
when on the road it's being charged by the tow vehicle alternator.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
Got a link to a datasheet? A real Li-ion battery CANNOT be overcharged without inducing failure. High cell voltage makes the metallic lithium ions plate on the anode and cause an internal short. All Li-ion batteries require a special charger external to the battery, a battery management system (BMS) to track charge cycles and prevent excessive discharge, AND internal fault protection circuits. Sometimes the BMS is built into the pack, sometimes its in the charger/ESC (like RC toy batteries). I suppose a small li-ion or li-iron phosphate battery with an internal charger/BMS/protection could be used as a car starter battery, but it'd be more expensive than a lead/acid with similar capacity.
So devils in the details when it comes to li-ion.
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 01-20-2020 at 01:30 PM. |
house fire
Li battery just started house fire locally that burnt down house. I don't trust them even though my pacemaker has one.
Li-ion and Li-iron batteries have been used by motorcycles (sportbikes) for several years now. Main reason being weight savings. The Li-ion require a special charger ... not sure about the Li-Iron. Not sure how the bike charging systems works with them, but evidently they are bolt in replacement, I guess it's possible they require some kind of add-on to the charging system.
Most new vehicles have a usb port for charging cell phones, wouldn't that be the same thing. I also have surface charger in my new Tacoma.
I could be wrong, but I think in most USB devices the device handles the charging details while the USB port just provides a certain volt/mamp supply. For instance a cell phone will have it's own circuitry to handle the charging.
I assume the Li-ion motorcycle batteries probably have their own built in circuitry to handle the "in use" charging. |
One of my personal injury lawyer friends told me LI batteries do cause fires-even things like Ryobi tool chargers!
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Lithium-Iron (LiFePO) batteries are much safer than Lithium-ion and can be used with stock charging systems. Make sure what you get has a BMS (battery management system). Check out https://earthxbatteries.com/ to get educated about Li batteries in general.
The Following 2 Users Say Thank You to hgerhardt For This Useful Post: | ||
All a USB port is doing is supplying a specified voltage and amperage capacity, nothing more.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Old thread ... but I just put an EarthX Lithium-Iron battery in my motorcycle. It's a very high compression, 1000cc V-twin, four valve, four gear driven cams, FI beast that eats conventional batteries like clockwork. Put in the biggest Lithium battery that would fit .. the bike freakin starts like it never has since I bought it 20 years ago.
Studied up on Lithium Iron .. very different than typical Lithium batteries as found in Teslas, phones etc. It's a "starting battery" not made for long term steady drain like an EV battery. Very safe, and approved for use in aircraft, and now being used by several OEM vehicle manufacturers. The one I bought has a built in Battery Management System. Can't be over charged or over depleted. Can be recharged in a fraction of the time of Lead Acid. One downside ... when it "dies" it does so with no warning, no "running down" it just stops. Much like a modern cordless tool. Can't be jumped by a conventional battery, can be jumped by another Lithium battery. Evidently people are getting them to last 10 ten years ... often never being once on a charger. I think I'm going to get a Lithium Jump-Pack anyway, just in case.
The Following User Says Thank You to dataway For This Useful Post: | ||
Mike |
The Following User Says Thank You to mzbk2l For This Useful Post: | ||
I have been running a Braille I34X for three years now. I do have the special charger. Both are not cheap. It has been the best battery I've had. I only put the charger on it maybe once during the winter just to make sure and it only takes 15 min to complete the charge.
I am careful not to do anything strange, jump start another car or use that battery to test anything. My alt is a 150A Powermaster. Nothing special. Elec fans, fuel pump, water pump, EFI etc so lots of load. At only 11 lb I can keep it in the front of the car down to 10.0 or 135.
[SIGPIC] Steve |
The Following User Says Thank You to XLR8STEVE For This Useful Post: | ||
I'm guessing it's the voltage drop you see with a Lead Acid battery after starting that messes with the electronics ... specially on a bike like this where the OEM battery size is about 20% smaller than it should be. After a couple minutes on the alternator the Lead Acid battery charges up to a voltage that the electronics like.
Yep. UPS lost an MD-11 freighter and crew in Saudi Arabia due to lithium-ion batteries. Boeing had to ground the entire 787 fleet due to lithium-ion batteries overheating in the cabin.
Those were not Lithium Iron (LiFePo) batteries, but the the more common type of Lithium-Cobalt, as found in phones, EV's etc. LiFePo batteries are much safer, but are unsuitable for use in things like rechargeable devices that constantly have large swings in state of charge.
