Old 12-28-2019, 09:24 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Default Lifter bore brace.
Under what conditions is a lifter bore recommended ?? Cam specs are below. Spring pressures according to Tin Indian who made my heads is 110-120 on the seat. About 300 open.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 12-28-2019, 09:54 AM
Steve C. Steve C. is offline
Post number 3
https://forums.maxperformanceinc.com...r+bore+bracing
Your intake lobe has about 161 degrees duration at 0.200" lift and the exhaust about 171
Old information here:
Old 12-28-2019, 10:01 AM
Thanks Steve. Very good info. I missed that one when I did a search some how.
Old 12-28-2019, 07:00 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
FYI :
I have a new brace kit out that I'll start advertise/selling here early next month.... Digitized from the 481988 PMD blocks. Each aluminum block has two clamping forces acting on it plus a 360° epoxy bond.. It'll also serve a job of retaining loose valve train parts from hitting the camshaft.
Kris.
( click the pics for a larger copy )
*** THE BIG BRACE is here ***
The Following 2 Users Say Thank You to RUDOLFSSON For This Useful Post:
Old 12-28-2019, 07:04 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Kris...looks very nice!
Old 12-28-2019, 07:21 PM
AIR RAM AIR RAM is offline
Originally Posted by 69GTO View Post
FYI :
Kris.
Wow... very nice... I like the oil drain back feature you added... at lest that's what those holes on the side appear to be.
what kind of pricing are you looking at?
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 12-28-2019, 08:04 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
That is a nice piece(s) Kris! As for the topic and the way I interpreted Ken Keefer (Pontiac Dude) from my recent post, just about any solid roller lifter would wisely benefit (insurance) from a lifter bore brace. The #2 and #6 intake lifter bores are totally unsupported due to the direction of the camshaft rotation (away from the block and towards the center webbing) would benefit from using lifter bore braces. I'm using a Comp 308R (262 @ .50 duration .575 lift) cam for this 428 build and I am using a (used) Butler Mega-Brage just so I don't have to worry or think about it...
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 12-29-2019, 12:22 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
All engines should be braced. Pontiac cut corners not following the RAV and SD blocks. It’s not only about the cam profile, but in the event a lifter takes a crap.
Calvin Hill
Hill Performance
708-250-7420
Old 12-29-2019, 02:26 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
FYI :
Kris.
Wow, those are beautiful! Do you think there might be an issue with expansion rate difference between aluminum and iron? As complex (and pretty) as the machine work appears to be, these look like an excellent candidate to 3-d print from DMLS-stainless (Direct Metal Laser Sintering). Those would have similar expansion rate as iron and have a nice rough surface for epoxy-bonding.
The Following User Says Thank You to hgerhardt For This Useful Post:
Old 12-29-2019, 01:23 PM
RUDOLFSSON's Avatar
Thanks for the interest,
this kit will always need some fitting so I’m not sure if 316/17-4 steel will be popular.. I do it the subtractive way as is.
Pontiac Yodas have used aluminum braces for years and poured aluminum in the heads as well w/o expansion issues that I’m aware of.
Final pricing not quite yet out there..
Ps.
Bare in mind that these are modeled after 70’s blocks and blocks will vary.. pre 70’s blocks seem to need more fitting work and they lack material in some areas.
Kris.
Old 12-29-2019, 01:51 PM
Half-Inch Stud's Avatar
...and i thought the #2 Exhaust Lifter bore was the worst/only problem.
Old 12-29-2019, 08:58 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Pretty slick looking!
Skip Fix
Old 12-30-2019, 02:22 AM
krisr's Avatar
krisr krisr is offline
Calvin Hill
Hill Performance
708-250-7420
I'm with you on that one Calvin, even if using a relatively mild hydraulic roller. A full SD brace kit doesn't cost much and you'll sleep better at night.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 12-30-2019, 10:33 AM
Old Goat Racer's Avatar
It is for me. I have a 455 4-bolt main '70 XF block standard bore with a hairline crack in #2 exhaust. That brace mite be the answer.
Everybody knows somthin.
Nobody knows everything !
Old 01-16-2020, 02:51 PM
janderson's Avatar
janderson janderson is offline
FYI :
Kris.
Interested when it’s released.
Old 01-16-2020, 04:07 PM
firechicken's Avatar
firechicken firechicken is offline
It has been advertised in the perf parts for sale forum already.
http://forums.maxperformanceinc.com/...d.php?t=836832
Old 01-16-2020, 07:14 PM
janderson's Avatar
Thanks.
Old 01-16-2020, 08:34 PM
RUDOLFSSON's Avatar
Thanks for the interest... I just posted up my new install guide as a huge image bundle down in the ad....
Kris.
